Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514248] |
Fri, 12 February 2010 19:32  |
Hi folks,
I'm trying to get an RCP build working with the Hudson/Buckminster combo.
The problem I have is that the feature is referencing third party OSGi libs that are only found in the Ibiblio Maven repo.
Importing the feature then results in:
ERROR [0002] : No repository found at http://www.ibiblio.org/maven2.
ERROR: No repository found at http://www.ibiblio.org/maven2.
ERROR: Errors and Warnings
org.eclipse.core.runtime.CoreException: Errors and Warnings
at org.eclipse.buckminster.runtime.BuckminsterException.wrap(BuckminsterException.java:109)
at org.eclipse.buckminster.core.materializer.MaterializationJob.internalRun(MaterializationJob.java:175)
at org.eclipse.buckminster.core.materializer.MaterializationJob.run(MaterializationJob.java:144)
Contains: [0002] : No repository found at http://www.ibiblio.org/maven2.
INFO: TAG-ID 0002 = Query for ...
I can work around this issue by adding an
mspecNode for the bundles in question that sets the materializer to filesystem; given the right installLocation I can even make them show up in the plugins directory of the site... but they are nested in some crazy maven folder structure ({$targetPlatform}/plugins/maven2/commons-io/...).
Whats the best way to resolve maven bundles into a p2 site?
Thanks in advance,
Phil
For your reference:
<mspec xmlns="http://www.eclipse.org/buckminster/MetaData-1.0"
name="Target Platform MSPEC" materializer="p2" installLocation="${targetPlatformPath}"
url="xxx.cquery">
<property key="target.arch" value="*" />
<property key="target.os" value="*" />
<property key="target.ws" value="*" />
<mspecNode namePattern="org\.apache\.lucene" exclude="true" />
<mspecNode namePattern="xxx\..*" exclude="true" />
<mspecNode namePattern="slf4j\..*" materializer="filesystem"
installLocation="${targetPlatformPath}/plugins" />
<mspecNode namePattern="org\.apache\.commons\.io"
materializer="filesystem" installLocation="${targetPlatformPath}/plugins" />
</mspec>
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap="xxx_hudson.rmap">
<cq:rootRequest name="xxx.product.feature" componentType="eclipse.feature" />
<cq:advisorNode namePattern=".*" useTargetPlatform="false"
useWorkspace="false" />
<cq:property key="target.arch" value="*" />
<cq:property key="target.os" value="*" />
<cq:property key="target.ws" value="*" />
</cq:componentQuery>
<rmap xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
<property key="base.path" value="D:/Workspace/Spielwiese" />
<searchPath name="xxx">
<provider readerType="local"
componentTypes="osgi.bundle,eclipse.feature" mutable="true"
source="true">
<uri format="file:/{0}/{1}/">
<bc:propertyRef key="base.path" />
<bc:propertyRef key="buckminster.component" />
</uri>
</provider>
</searchPath>
<searchPath name="galileo">
<provider readerType="eclipse.import" componentTypes="osgi.bundle,eclipse.feature"
mutable="false" source="false">
<uri format="http://download.eclipse.org/releases/galileo?importType=binary" />
</provider>
</searchPath>
<searchPath name="maven">
<provider xsi:type="mp:MavenProvider" readerType="maven2"
componentTypes="osgi.bundle" mutable="false" source="false">
<uri format="http://mirrors.ibiblio.org/pub/mirrors/maven2" />
<mp:mappings>
<mp:entry name="slf4j.api" groupId="org.slf4j" artifactId="slf4j-api" />
<mp:entry name="slf4j.simple" groupId="org.slf4j"
artifactId="slf4j-simple" />
<mp:entry name="org.apache.commons.io" groupId="commons-io"
artifactId="commons-io" />
</mp:mappings>
</provider>
</searchPath>
<locator searchPathRef="xxx" failOnError="false" />
<locator searchPathRef="galileo" failOnError="false" />
<locator searchPathRef="maven" />
</rmap>
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514265 is a reply to message #514263] |
Sat, 13 February 2010 04:21   |
Back on 3.5, I have tried another approach using ANT GET maps, but this time I get no component match found for the bundles in question.
ANT GET MAP
plugin@org.apache.commons.io,1.4.0=GET,http://mirrors.ibiblio.org/pub/mirrors/maven2/commons-io/commons-io/1.4/commons-io-1.4.jar
plugin@slf4j.api,1.5.10=GET,http://mirrors.ibiblio.org/pub/mirrors/maven2/org/slf4j/slf4j-api/1.5.10/slf4j-api-1.5.10.jar
plugin@slf4j.simple,1.5.10=GET,http://mirrors.ibiblio.org/pub/mirrors/maven2/org/slf4j/slf4j-simple/1.5.10/slf4j-simple-1.5.10.jar
New RMAP
<property key="svn.user" value="philipp" />
<property key="svn.pass" value="..." />
<provider readerType="svn"
source="true">
<uri format="svn://{0}:{1}@htpc/xxx/trunk/{2}/">
<bc:propertyRef key="svn.user" />
<bc:propertyRef key="svn.pass" />
</uri>
</provider>
</searchPath>
</provider>
</searchPath>
<provider readerType="eclipse.import" componentTypes="osgi.bundle"
<uri format="file:/D:/supplemental-plugins.map" />
</provider>
</searchPath>
<locator searchPathRef="maven"/>
</rmap>
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514269 is a reply to message #514263] |
Sat, 13 February 2010 05:03   |
Hi Philipp,
You're experiencing an incompatibility issue. Probably a mix between 3.5 and 3.6 bundles. Are you using Subversion from
our External site? If so, please read my latest posting "Reorganization of our external sites."
Thomas Hallgren
On 02/13/2010 10:03 AM, Philipp Nanz wrote:
> Hi Thomas,
> thanks for the quick reply.
> I have given it a try with 3.6 (freshly installed a few minutes ago via
> director), unfortunately that results in another error:
> D:\p2\buckminster-3.6>java
> -Dbuckminster.output.root=/D:/hudson/jobs/TargetPlatf
> orm/workspace//buckminster.output
> -Dbuckminster.temp.root=/D:/hudson/jobs/Target
> Platform/workspace//buckminster.temp
> -DtargetPlatformPath=/D:/hudson/jobs/Target
> Platform/workspace//targetPlatform -jar
> plugins/org.eclipse.equinox.launcher_1.1
> 0.v20100208.jar -application org.eclipse.buckminster.cmdline.headless
> -data /D:
> /hudson/jobs/TargetPlatform/workspace/ --loglevel info -S
> D:\hudson\jobs\TargetP
> latform\builds\2010-02-13_09-42-59/commands.txt
> INFO: import 'file:/D:/target-platform.mspec'
> WARN: Use of deprecated value for attribute <provider readerType>. Was
> 'eclipse
> import', should be 'p2' : file:/D:/xxx_hudson.rmap, line 23.
> ERROR [0001] : java.lang.NoSuchMethodError:
> org.eclipse.buckminster.core.resol
> ver.NodeQuery.getRevision()J
> INFO: TAG-ID 0001 = Query for xxx.product.feature:eclipse.feature
> I have tried running it with debug, but even then I get no stacktrace.
> So I have no idea where this thing is coming from :-/
> but then again even if it would work, it wouldn't really be an option
> for me though because the hudson-buckminster plugin doesn't support 3.6
> yet.
> As for Orbit, one of the wanted bundles isn't listed there :(
> Thanks for your time,
> Phil
FUDForum. Page generated in 0.09276 seconds
