Home » Modeling » GMF (Graphical Modeling Framework) » adapting underlying models - loading a emf model and editing a different one
adapting underlying models - loading a emf model and editing a different one [message #513930] Thu, 11 February 2010 07:18 Go to next message
Originally posted by: murbieta.gpi.com.ar
Hi, for sake of simplicity i have developed a simplified model for an
existing XSD and also generated its GMF editor. Additionally i have
derivated the XSD schema and generated its EMF components.
So, i'm looking for the right place to introduce a hand-made adapter
that maps when loading the persisted model to the one that will be used
in-memory. this adapter should be called when user performs a save or
load operation.
I have checked GenentityDiagramEditorUtil.createDiagram() and i tried to
introduce a ToBePersistedModel for having both model in memory. It looks
like:
attachModelToResource(createToBePersistedModel(), diagramResource);
AModel modelToBeEdited=createToBeEditedInViewMode()
Diagram diagram = ViewService.createDiagram(modelToBeEdited,
ModelEditPart.MODEL_ID,
GenentityDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT);
if (diagram != null) {
diagramResource.getContents().add(diagram);
diagram.setName(diagramName);
diagram.setElement(modelToBeEdited);
But it doesn work..
Thanks in advance.
Re: adapting underlying models - loading a emf model and editing a different one [message #513952 is a reply to message #513930] Thu, 11 February 2010 13:48 Go to previous message
--------------080703070906060901070600
Matias,
I wonder if this option would help do additional processing during load
and save?
* A {@link ResourceHandler} value that can be registered to
receive call backs
* for loading from an input stream or saving to an output stream.
* @see org.eclipse.emf.ecore.xmi.XMLResource.ResourceHandler
* @see org.eclipse.emf.ecore.xmi.impl.BasicResourceHandler
String OPTION_RESOURCE_HANDLER = "RESOURCE_HANDLER";
In any case, I suspect you're best off to try to hide all this in your
resource implementation rather than be tweaking GMF itself.
> used in-memory. this adapter should be called when user performs a
> save or load operation.
> to introduce a ToBePersistedModel for having both model in memory. It
> looks like:
> But it doesn work..
> Thanks in advance.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Matias,<br>
<br>
and save?<small><br>
</small>
<blockquote><small>&nbsp; /**</small><br>
<small>&nbsp;&nbsp; * A {@link ResourceHandler} value that can be registered to
receive call backs </small><br>
<small>&nbsp;&nbsp; * for loading from an input stream or saving to an output
stream.</small><br>
<small>&nbsp;&nbsp; * @see org.eclipse.emf.ecore.xmi.XMLResource.ResourceHandler</small ><br>
<small>&nbsp;&nbsp; * @see org.eclipse.emf.ecore.xmi.impl.BasicResourceHandler</small> <br>
<small>&nbsp;&nbsp; */</small><br>
<small>&nbsp; String OPTION_RESOURCE_HANDLER = "RESOURCE_HANDLER";</small><br>
</blockquote>
resource implementation rather than be tweaking GMF itself.<br>
<br>
<br>
<blockquote cite="mid:hl1du3$kse$1@build.eclipse.org" type="cite">Hi,
<br>
load operation.
<br>
looks like:
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; diagram.setElement(modelToBeEdited);
<br>
&nbsp;&nbsp;&nbsp;&nbsp;}
<br>
<br>
But it doesn work..
<br>
<br>
Thanks in advance.
<br>
<br>
</blockquote>
</body>
</html>
--------------080703070906060901070600--
Previous Topic:Problem with multiple Link mappings
Next Topic:edit part disposal
Current Time: Sat Jul 19 08:52:33 EDT 2025
Powered by FUDForum. Page generated in 0.05672 seconds
