Home » Modeling » EMF » [CDO] Transaction Exception(Transaction Exception due to "id instanceof CDOIDTemp")
[CDO] Transaction Exception [message #513552] Wed, 10 February 2010 09:47 Go to next message
All,
I am playing with the material given by Eike at Eclipse summit during the Advanced Programming Techniques with EMF and CDO.
I have a problem when creating a simple Root Eobject within a transaction:
CDOSession session = openSession();
session.getPackageRegistry().putEPackage(InventoryPackage.eI NSTANCE);
// open the transaction
CDOTransaction transaction = session.openTransaction();
// create the resource
CDOResource resource = transaction.getResource("/edine/resto2.inventory");
// Work with resource
Restaurant restaurant = InventoryFactory.eINSTANCE.createRestaurant();
resource.getContents().add(restaurant);
// Commit the transaction
transaction.commit();
session.close();
But I have got a TransactionException due to the "id instanceof CDOIDTemp".
Have you got any idea ?
The exception is:
Exception in thread "main" org.eclipse.net4j.util.transaction.TransactionException: Rollback in DBStore: java.lang.IllegalArgumentException: id instanceof CDOIDTemp
at org.eclipse.emf.cdo.common.id.CDOIDUtil.getLong(CDOIDUtil.ja va:87)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getMe taID(MetaDataManager.java:72)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.getTableName(AbstractMappingStrategy.java:256)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping.initTable(AbstractHorizontalCla ssMapping.java:82)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping. <init>(AbstractHorizontalClassMapping.java:76)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ho rizontalAuditClassMapping. <init>(HorizontalAuditClassMapping.java:64)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ho rizontalAuditMappingStrategy.doCreateClassMapping(Horizontal AuditMappingStrategy.java:29)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.createClassMapping(AbstractMappingStrategy.java:3 84)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.getClassMapping(AbstractMappingStrategy.java:411)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write Revision(DBStoreAccessor.java:359)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write Revisions(DBStoreAccessor.java:342)
at org.eclipse.emf.cdo.spi.server.StoreAccessor.write(StoreAcce ssor.java:145)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.acces s$4(DBStoreAccessor.java:1)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:80)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr ogressDistributor.java:96)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write (DBStoreAccessor.java:299)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext Impl.write(TransactionCommitContextImpl.java:273)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication$1.runLoop(CommitTransactionIndication.jav a:72)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication$1.runLoop(CommitTransactionIndication.jav a:1)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicatingCommit(CommitTransactionIndicat ion.java:280)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:173)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:139)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:650)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:675)
at java.lang.Thread.run(Thread.java:595)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactio nStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:6 3)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:621)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:635)
at org.gastro.exercises.Exercice11b.main(Exercice11b.java:90)
Re: [CDO] Transaction Exception [message #513610 is a reply to message #513552] Wed, 10 February 2010 06:56 Go to previous messageGo to next message
Am 10.02.2010 15:47, schrieb Sabri Skhiri:
> All,
> transaction:
putEPackage() shouldn't be necessary.
Shouldn't that be createResource()?
> session.close();
> CDOIDTemp".
> The exception is:
I admit that te exception message is not very convenient :P
Which exact version of CDO are you using?
Cheers
/Eike
> ssMapping.java:82)
> ssor.java:145)
> ion.java:280)
> lExecutor.java:675)
Re: [CDO] Transaction Exception [message #513624 is a reply to message #513610] Wed, 10 February 2010 12:30 Go to previous messageGo to next message
Hi Eike,
In the plug-in detail I found:
Plug-in version 3.0.0.v2009XX. for all CDO plug-ins. The same for CDO features all pre-fixed by 3.0.0.
Actually I re-use the Eclipse version I got from the Eclipse Summit workshop.
Do you need more information ?
Thanx !
Sabri.
Re: [CDO] Transaction Exception [message #513756 is a reply to message #513624] Thu, 11 February 2010 01:59 Go to previous messageGo to next message
Have you followed my advice to use createResource() instead of
getResource()?
Cheers
/Eike
Am 10.02.2010 18:30, schrieb Sabri Skhiri:
> Hi Eike,
> workshop.
> Thanx !
> Sabri.
Re: [CDO] Transaction Exception [message #513794 is a reply to message #513756] Thu, 11 February 2010 05:52 Go to previous messageGo to next message
Actually I tried with a createResource(), with the getorCreateResource() and I have even tried with creating a resource with the CDO client UI. But even with the last try, I managed to create the resource with the client UI, and From my client code, I manage to get it but always the same exception on commit.
BTW, for a production or prototype do you advise to use CDO 3.0 or 2.0 ?
Sabri.
Re: [CDO] Transaction Exception [message #513797 is a reply to message #513794] Thu, 11 February 2010 05:58 Go to previous messageGo to next message
Am 11.02.2010 11:52, schrieb Sabri Skhiri:
For production 2.0 latest (builds to be provided soon again)
For prototyping 3.0 latest.
Cheers
/Eike
Re: [CDO] Transaction Exception [message #513915 is a reply to message #513797] Thu, 11 February 2010 11:23 Go to previous messageGo to next message
Eike,
I have tried by creating a transaction with the CDO UI Client. The creation of an empty resource works, but if I try to create something within this resource it fails when I commit with this same strange exception. The same if I try from a client Transaction API.
Therefore, I downloaded all the CDO 3.0 sources from repository and I re-test the same use case, it fails with the same exception.
Thank you,
Sabri.
Re: [CDO] Transaction Exception [message #513951 is a reply to message #513915] Thu, 11 February 2010 08:54 Go to previous messageGo to next message
Am 11.02.2010 17:23, schrieb Sabri Skhiri:
> Eike,
Can you send me a zip with a test case or a Java program that I can use
to reproduce the problem?
Cheers
/Eike
Re: [CDO] Transaction Exception [message #514036 is a reply to message #513915] Fri, 12 February 2010 04:23 Go to previous messageGo to next message
Hi Sabri,
I've played with the zips you sent. There's one obvious bug in your
model plugin.xml. The referenced package class does not exist because
you added a package base prefix. Fixing that should enable you to import
the XML file. But you're right, there seems to be a regression in the
DBStore that causes temporary meta IDs not being remapped after
successful commits. Please file a bugzilla.
If you want to go ahead, please try out the MEMStore instead of the DBStore:
IStore store = MEMStoreUtil.createMEMStore();
Cheers
/Eike
> Eike,
> Thank you,
> Sabri.
Re: [CDO] Transaction Exception [message #514394 is a reply to message #514036] Mon, 15 February 2010 03:33 Go to previous message
OK thanks ! By replacing the DB store it works indeed.
I will fill in a bugzilla.
thanks for the support.
Previous Topic:[CDO] instance objects and java Serializable
Next Topic:Is it possible to save more than one object in one resource?
Current Time: Sat Jul 19 17:27:24 EDT 2025
Powered by FUDForum. Page generated in 0.05758 seconds
