Home » Eclipse Projects » Rich Client Platform (RCP) » How ViewPart response to some EditorPart Action(How ViewPart catch the EditorPart Action in a better design pattern)
How ViewPart response to some EditorPart Action [message #513830] Thu, 11 February 2010 07:43 Go to next message
I am writing an RCP Application and new to RCP. Now I have a editor part with a Text Control..When I select text in the Text Control and right click , a pop up menu will pop up. When I push one of the menu, I want to another viewpart can respond it? Now I am using following code to achieve this:
//In Editor Part
Event drawTextEvent = new Event();
drawTextEvent.data = selectText;
handlerService.executeCommand(
"command.drawText",
drawTextEvent);
//In command handler
IWorkbenchWindow window = HandlerUtil.getActiveWorkbenchWindow(event);
IWorkbenchPage page = window.getActivePage();
GlyphLayoutView layout = (GlyphLayout)page.findView(GlyphLayout.ID);
layout.call(event.getTrigger().data);
I wonder if there is better way to achieve this between editor and viewpart? Because some parameter should be passed to viewpart.
Re: How ViewPart response to some EditorPart Action [message #513839 is a reply to message #513830] Thu, 11 February 2010 03:32 Go to previous messageGo to next message
What you are doing is all API and will work fine.
One way to "communicate" between the editor and view is to have the
editor simply post its selection, and have the view react to selection
change events.
Another would be to simply move that code into your editor and call that
from your handler.
updateView() {
GlyphLayoutView layout = (GlyphLayout) getSite()
.getPage().findView(GlyphLayout.ID);
layout.call(selectedText);
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How ViewPart response to some EditorPart Action [message #513841 is a reply to message #513839] Thu, 11 February 2010 08:37 Go to previous messageGo to next message
is the "One way to "communicate" between the editor and view is to have the
change events.
" means add a selection listener in the viewer and react the selection changed?
I am aim to look for a relative loose-coupled communication in the editor and viewer? Since the code I wrote is not very well-designed first my first sense and hard to transfer and refactor Smile.
Anyway, thanks a lot. I think your way is also good way and I will try it.
Re: How ViewPart response to some EditorPart Action [message #513914 is a reply to message #513841] Thu, 11 February 2010 06:24 Go to previous messageGo to next message
> change events.
> changed?
Yes, it's the most common way and provides a level of decoupling. See
http://www.eclipse.org/articles/Article-WorkbenchSelections/ article.html
PW
Paul Webster
Re: How ViewPart response to some EditorPart Action [message #514005 is a reply to message #513914] Thu, 11 February 2010 22:02 Go to previous message
Thanks for your help . It's great for a freshmen to RCP Laughing
Previous Topic:Java Webstart problems
Next Topic:How do I find out if the content assist popup window is currently showing?
Current Time: Sat Jul 19 14:14:31 EDT 2025
Powered by FUDForum. Page generated in 0.03607 seconds
