Home » Eclipse Projects » Rich Client Platform (RCP) » Config.ini(Config.ini)
Config.ini [message #513697] Wed, 10 February 2010 16:03 Go to next message
I have a basic question for changing the config.ini
Where do need to make change to make changes in the generated config ini.
If the answer is Run Configuration>>Argument >> in which file it will change??
Also how the application config ini gets populated.
Amit
[Updated on: Wed, 10 February 2010 18:30] by Moderator
Re: Config.ini [message #518394 is a reply to message #513697] Wed, 03 March 2010 18:29 Go to previous message
Hi Amit,
In the product configuration.
Best Regards,
Wim Jongman
-- The Definition of an Upgrade: Take old bugs out, put new ones in.
(Eclipse Old Skool Quote Service)
> Hi
change??
> Thanks
> Amit
Previous Topic:Property Sheet View
Next Topic:Program change Property sheet column width
Current Time: Sat Jul 19 19:32:54 EDT 2025
Powered by FUDForum. Page generated in 0.02865 seconds
