Riena 2.0 [message #513003] |
Mon, 08 February 2010 04:50 |
Hi Riena users,
as you are (hopefully) aware and as we are indicating with our major version number change, we are doing a number of API
breaking changes in this version of Riena. Things that bothered us for too long or even worse, bothered YOU too long.
API breaking also means that your app that used to work, needs a little lift up to work again when migrating to a new
milestone or release version.
However we are try to do this as smooth as possible. So we created a wiki page that covers broken APIs
http://wiki.eclipse.org/Riena_Migrating_to_2.0_from_1.2
We will try our best the crunch the API changes between NOW and M6. So we already changed the way a SubModuleView is
defined and we are going to start working on the Assembly extension point to reduce the number of redundant and
missleading fields.
So we hope this will make things easier and lighter to consume. If you are unclear or confused about any of the changes,
please let us know through the various channels....
regards
christian campo
FUDForum. Page generated in 0.03311 seconds
