Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Change IModelElement icons (in outline, explorer, completion)
Change IModelElement icons (in outline, explorer, completion) [message #500932] Mon, 30 November 2009 05:43 Go to next message
I would like to change IModelElement icons displayed in outline,
explorer and completion, but with no success :-(
I've tried to look around ModelElementLabelProvider class, but I still
have problems with icons size (those I changed are not displayed with
the right size), and I'm not sure to go the right way...
If someone could help ... (thanks in advance)
David
Re: Change IModelElement icons (in outline, explorer, completion) [message #501101 is a reply to message #500932] Mon, 30 November 2009 23:04 Go to previous messageGo to next message
Hi David,
Please look into org.eclipse.dltk.ui.modelLabelProvider extension point.
It's allow any customization of outline, etc by providing custom label provider.
You could check example implementation in TCL in class TclModelLabelProvider.
If you need to add some additional elements you also could use following extension points ( for customization of outline, script explorer content and element ordering)
org.eclipse.dltk.ui.modelCompareProvider
org.eclipse.dltk.ui.modelContentProvider
Andrei.
Re: Change IModelElement icons (in outline, explorer, completion) [message #501667 is a reply to message #501101] Thu, 03 December 2009 06:13 Go to previous messageGo to next message
Andrei Sobolev a écrit :
> Hi David,
> provider.
> Best regards,
> Andrei.
Hi Andrei,
Thank you for your answer.
I’ve tried to use org.eclipse.dltk.ui.modelLabelProvider extension
point, as in Tcl project. It works very well for all explorer part, but
I still have problems with icons size in Outline view : they are
displayed bigger than they are in explorer part.
In Tcl project, the only custom objects that are displayed are Tcl
Packages (tcl_packagefolder_obj.gif), and this kind of object is not
displayed in the Outline, so I can’t compare the behavior.
I also noticed that IModelElement objects displayed in completion
proposals do not react the same way : I mean that modelLabelProvider is
not used in this case (I need to override
CompletionProposalLabelProvider to do what I want). I think
modelLabelProvider extension point should also be used by completion.
Thanks in advance for your help,
David
Re: Change IModelElement icons (in outline, explorer, completion) [message #501849 is a reply to message #501667] Thu, 03 December 2009 23:05 Go to previous messageGo to next message
Hi David,
The custom icons size in the Outline view was fixed in the last
integration build. Could you please test that it works for you?
We'll check what can be improved regarding completion proposals label
providers.
Alex
Re: Change IModelElement icons (in outline, explorer, completion) [message #501886 is a reply to message #501849] Fri, 04 December 2009 04:59 Go to previous messageGo to next message
Hi Alex,
Thanks a lot, it works fine now in outline view.
David
Re: Change IModelElement icons (in outline, explorer, completion) [message #512862 is a reply to message #501849] Sun, 07 February 2010 22:52 Go to previous messageGo to next message
Alex Panchenko a écrit :
> Hi David,
> providers.
> Regards,
> Alex
Hi Alex,
I think there is the same problem of icon size in search view. I have
problem in my plugin search page, but I also see it in Ruby plugin.
David
Re: Change IModelElement icons (in outline, explorer, completion) [message #513224 is a reply to message #512862] Tue, 09 February 2010 07:34 Go to previous messageGo to next message
Hi David,
Thank you for reporting this.
I've fixed in CVS HEAD the size of source module icons in Search view, so the next integration build should work correctly.
Alex
Re: Change IModelElement icons (in outline, explorer, completion) [message #514399 is a reply to message #513224] Mon, 15 February 2010 03:43 Go to previous messageGo to next message
> Hi David,
> Regards,
> Alex
Hi Alex,
I have downloaded the latest build, and it works fine now.
Thanks a lot for your reactivity.
David
Re: Change IModelElement icons (in outline, explorer, completion) [message #519986 is a reply to message #514399] Wed, 10 March 2010 12:22 Go to previous messageGo to next message
Like dalar I wish to change change Images in quick outilne. In my case I would like to to hava an icon dor private classes. In java it is a non sense, but it's relevant in my language.
Anyway I tried to extend LabelProvider but when debugging, I've noticed that the getImage() function receive SourceType object and related objects. The behavior of my outline changed using an regular LabelProvider.
How can I keep the default DLTK outline behavior and just change one image ?
Re: Change IModelElement icons (in outline, explorer, completion) [message #520129 is a reply to message #519986] Wed, 10 March 2010 23:28 Go to previous messageGo to next message
Hi Kevin,
What I do is :
- extend LabelProvider class
- override "public Image getImage(Object element)" method in my
xxxLabelProvider class. In this class, check for element flags like
example below (you'll have to adapt it to your case).
IMember member = getMember(element);
if (member == null)
return null;
try
if (member.exists())
int flags = member.getFlags();
// Special icon for private type
if (member instanceof IType
&& (flags & Modifiers.AccPrivate) != 0)
return getPrivateMethodIcon(); // return your special icon
catch (ModelException e)
return null; // will enter default DLTK behavior
Hope this helps you
David
[Updated on: Thu, 11 March 2010 07:21] by Moderator
Re: Change IModelElement icons (in outline, explorer, completion) [message #521968 is a reply to message #520129] Fri, 19 March 2010 09:48 Go to previous message
I had already manage to get the icon changed. Neither the less, what I was searching for was to recover DLTKs behavior on text labels going along with the outline's icons. It's deeply inpired from rour example Smile
public class YourLabelProvider extends LabelProvider {
    public String getText(Object element) {
         * Override this method and return null activate DLTK's default
         * behavior. Else way, parent class just returns toString(), which is
         * less convenient
        return null;
    public Image getImage(Object element) {
        if (member == null)
            return null;
        try {
            if (member.exists()) {
        } catch (Exception e) {
        // Stick to default DLTK behavior
        return null;
    private IMember getMember(Object element) {
        if (element instanceof IMember) {
            return (IMember) element;
        return null;
    private Image getPrivateMethodIcon() throws IOException {
        return Activator.getImage("/img/class_obj.gif");
Previous Topic:[BUILD] S-2.0M6-201003160541
Next Topic:DLTK 2.0 , Ruby ?
Current Time: Sun Jul 20 15:08:11 EDT 2025
Powered by FUDForum. Page generated in 0.05053 seconds
