Home » Eclipse Projects » Eclipse Platform » file format of .project
file format of .project [message #512284] Thu, 04 February 2010 09:28 Go to next message
Is there somewhere a description on the file format of the .project file
found in every eclipse project?
I was not able to find any schema description, or even a text file
telling what tags/properties are possible and what they actually mean.
Best Regards
Kristof
Re: file format of .project [message #512408 is a reply to message #512284] Thu, 04 February 2010 18:16 Go to previous messageGo to next message
it is a better idea not to play around with .project files. Actually,
you can look on the IProject, IProjectDescription interfaces and the
corresponding sub-elements (natures, builders and other attributes)...
Kind regards,
Simon
Kristof Szabados schrieb:
> Best Regards
> Kristof
Re: file format of .project [message #512575 is a reply to message #512284] Fri, 05 February 2010 09:19 Go to previous messageGo to next message
As Simon says, there is API to deal with projects. See
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/resAdv.htm
for project natures and builders. That document also includes the other
project related APIs.
We do publish a description of the file (I was surprised) in
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/reference/misc/project_description_file.ht ml
But use the provided APIs to modify it.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: file format of .project [message #512619 is a reply to message #512575] Fri, 05 February 2010 11:21 Go to previous messageGo to next message
> PW
Thank you for the information.
I know it's not the best way, but most probably I will have to create a
shell script that converts from our old project format to "an eclipse
based project format".
BR
Kristof
Re: file format of .project [message #513022 is a reply to message #512408] Mon, 08 February 2010 10:30 Go to previous message
Le 05/02/2010 00:16, Simon Zambrovski a écrit :
> Kind regards,
> Simon
>> Hi,
By the way, is there a GUI way to set the comment of a project (from
IProjectDescription) ?
Previous Topic:Contributing editor actions to specific place in the toolbar
Next Topic:Help Contents breaks
Current Time: Sun Jul 20 08:58:44 EDT 2025
Powered by FUDForum. Page generated in 0.04883 seconds
