Home » Eclipse Projects » Rich Client Platform (RCP) » Positioning the jobs progress indicator on the status line(How do I control where the jobs progress indicator goes on the status line?)
Positioning the jobs progress indicator on the status line [message #512383] Thu, 04 February 2010 15:30 Go to next message
I have a status line, it has some items on it already that i've added previously.
I now need the Jobs progress indicator to be visible when a job is running. So, I turned on configurer.setShowProgressIndicator(true) in preWindowOpen(). I told my jobs to set setSystem( true ) on each of them.
However, the resulting behavior is that the space on the status line that *used* to have status messages in it (which I post messages to on occasion) is now cut in half by a draggable-dashed-line all the time. The Jobs progress indicator shows up to the right of this when a job is active, but it kills the amount of space i have to post status messages now.
Is there any way to programmatically pick where the Jobs progress monitor goes?
I'd love it if it stayed on the far left side of the status line (where there is lots of wasted space).
Any ideas would be appreciated.
thanks,
-dave
[Updated on: Tue, 16 February 2010 11:11] by Moderator
Re: Positioning the jobs progress indicator on the status line [message #518387 is a reply to message #512383] Wed, 03 March 2010 18:13 Go to previous messageGo to next message
Hi Dave,
I'm not sure that you have to make it visible all the time. Just use the run
method of the workbenchwindow class. Also you can get a progressmonitor from
the view- or editorsite actionbars to show progress when you need it.
Best Regards,
Wim Jongman
-- ... File not found. Should I fake it? (Y/N)
(Eclipse Old Skool Quote Service)
previously.
goes?
> thanks,
> -dave
Re: Positioning the jobs progress indicator on the status line [message #521225 is a reply to message #518387] Tue, 16 March 2010 15:19 Go to previous message
I want the area visible, but I want to be able to choose the location. It seems to default to the lower right hand corner. If I could make it always show up in the upper right hand corner, i would be very happy.
I've not seen any API calls that will help me do this, although I can drag it by mouse to where I want it.
thanks,
-dave
Previous Topic:Advice on posting
Next Topic:JDK 6 webstart and eclipse 3.4.2
Current Time: Sat Jul 19 16:14:32 EDT 2025
Powered by FUDForum. Page generated in 0.04361 seconds
