Home » Language IDEs » ServerTools (WTP) » XML Catalog User entries ignored by embedded tomcat
XML Catalog User entries ignored by embedded tomcat [message #512108] Wed, 03 February 2010 17:53 Go to next message
I'm extending spring with a namespace. The way that works you provide a schema xsd file in your jar and hook into spring xml processing for schema validation and such. In eclipse, the schema is expected to be available at a given location. For instance:
<beans xmlns="http://www.springframework.org/schema/beans"
xmlns:ws="http://mywork/namespace
xsi:schemaLocation="
http://www.springframework.org/schema/beans/spring-beans-2.5 .xsd
http://mywork/namespace.xsd
Now.. I can add an entry in the eclipse XML catalog so that the XML editor works. However, when I launch my webapp with an embedded WTP tomcat instance, I see this error:
Caused by: org.xml.sax.SAXParseException: cvc-complex-type.2.4.c: The matching wildcard is strict, but no declaration can be found for element 'myelement'
This is the same error the editor was giving before I added the user entry to xml catalogs. So, does WTP use those entries as well? It would appear not. Anyone seen this and have a solution?
Thanks.
Re: XML Catalog User entries ignored by embedded tomcat [message #512110 is a reply to message #512108] Wed, 03 February 2010 17:58 Go to previous messageGo to next message
I should note that when I bundle up my app into a war and deploy to a standalone java instance .. it works just fine.
Re: XML Catalog User entries ignored by embedded tomcat [message #512322 is a reply to message #512108] Thu, 04 February 2010 06:50 Go to previous messageGo to next message
Hi David, I don't know much about how embedded servers work, but I would
suspect they don't ship by default or use the workspace XML catalog. Looking
at the problem from a pure XML point of view, I suspect it would be up to
the program that parses that XML file to provide an entity resolver, perhaps
delegating to an XML catalog to resolve your schema. The schema itself may
be located on the web or shipped with your application. I would suggest you
ask the Spring folks if they support this scenario.
Regards, Valentin
"David Durham" <david.durham.jr@gmail.com> wrote in message
news:hkcupq$mgb$1@build.eclipse.org...
> 'myelement'
> Thanks.
Re: XML Catalog User entries ignored by embedded tomcat [message #512348 is a reply to message #512322] Thu, 04 February 2010 13:01 Go to previous messageGo to next message
The app works fine when I war it up and place it in a standalone server -- just doesn't work within the WTP tomcat instance. Spring supports the xsd not being available publicly, it has a mapping file where you tell it where to fine the xsd file on the classpath. And that works in a standalone tomcat instance, just not within wtp.
Dave
Re: XML Catalog User entries ignored by embedded tomcat [message #512357 is a reply to message #512348] Thu, 04 February 2010 08:36 Go to previous messageGo to next message
> Dave
Where is this schema file in your project?
Larry
Re: XML Catalog User entries ignored by embedded tomcat [message #512373 is a reply to message #512357] Thu, 04 February 2010 14:29 Go to previous messageGo to next message
In a jar on the classpath.
I have a war that depends on my spring extension library that includes a xsd.
Re: XML Catalog User entries ignored by embedded tomcat [message #512588 is a reply to message #512373] Fri, 05 February 2010 09:40 Go to previous messageGo to next message
> xsd.
The few clues so far aren't pointing to any obvious reasons that would
explain the difference in behavior. To clarify, is this "jar" just a
jar or is it another project in your workspace that your Dynamic Web
project depends on?
Larry
Re: XML Catalog User entries ignored by embedded tomcat [message #512622 is a reply to message #512588] Fri, 05 February 2010 11:28 Go to previous messageGo to next message
Does it really matter where exactly it is on the classpath? Ultimately it resides in a jar file in the .metadata/.plugins/org.eclipse.wst.server.core/tmp0/.../WEB- INF/lib, but it could also be in .metadata/.plugins/.../WEB-INF/classes and it still would not work.
It's the setup of the embedded tomcat container that is causing my problem. I have not dug into the embedded environment enough to say, "Ok the parser is setup this way .. so that's why it's not working in one scenario, but my standalone server does work because a parser is setup this way." Instead, I was kind of hoping that someone would say "this is how you can make the embedded tomcat container honor the user entries in preferences -> XML Catalog, .. or no you can not do that, and we'll note that as a feature request."
In fact, I was going to add it as a feature request myself, but bugzilla comes back with:
Sorry, either the product WTP Server Tools does not exist or you aren't authorized to enter a bug into it.
at: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20Se rver%20Tools
Dave
Re: XML Catalog User entries ignored by embedded tomcat [message #512641 is a reply to message #512622] Fri, 05 February 2010 08:02 Go to previous messageGo to next message
> comes back with:
> at:
> Dave
The difference in the behavior between the embedded Tomcat and your
external Tomcat is likely due to a configuration difference between the
Tomcats, a bug or quirk in spring, a bug in WTP, or some combination of
these. The prior question relates to the "bug in WTP" possibility,
based on some past history. I just need to confirm that the jar is
where it belongs and it contains the xsd where it should. If this is
coming from project in your workspace and a certain past bug (don't
remember the number) has reappeared, then the answer could be "no". To
avoid wasting time, I need to eliminate this before pursuing other
possibilities.
If the jar and xsd are where they should be under "tmp0/.../WEB-
INF/lib", or you get the same error putting the xsd in the appropriate
location under WEB-INF/classes, then it would help to have a stacktrace
for the startup error you are seeing, if one is available in some log
output. It would also help to know which version of WTP, Spring, and
Tomcat you are using.
Larry
Re: XML Catalog User entries ignored by embedded tomcat [message #512645 is a reply to message #512641] Fri, 05 February 2010 13:21 Go to previous messageGo to next message
Thanks.
I filed a report here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=301985
It has the stack trace you mention. And the xsd file is in the jar file in WEB-INF/lib where it should be.
Thanks again,
Dave
Re: XML Catalog User entries ignored by embedded tomcat [message #512647 is a reply to message #512641] Fri, 05 February 2010 13:26 Go to previous message
>> still would not work. It's the setup of the embedded tomcat container
>> feature request."
>> at:
>> Thanks,
>> Dave
> possibilities.
> Cheers,
> Larry
Never mind about the stacktrace, I saw Bug 301985.
Larry
Previous Topic:EL Syntax Error for no-args function
Next Topic:How to get Get JavaScript" type resolution" in script blocks of HTML/JSP files
Current Time: Sat Jul 19 14:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.03426 seconds
