javax.naming.NoInitialContextException using "generate tables from entities" [message #511299] |
Mon, 01 February 2010 03:13  |
Presently I have a working persistence.xml file - I can deploy my project and it runs correctly, storing entities in the database using container managed transactions. Unfortunately when I run "generate tables from entities" I get the exception listed below. Changing transaction-type to resource_local to bypass the app server works fine, but container managed doesn't seem to work. Any ideas?
<persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="SCBCDEntities" transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<jta-data-source>DBConn1</jta-data-source>
<class>examples.persistence.User</class>
<class>examples.persistence.Item</class>
<class>examples.persistence.Bid</class>
<properties>
<property name="eclipselink.target-server" value="WebLogic_10"/>
<property name="eclipselink.logging.level" value="FINEST"/>
<property name="eclipselink.ddl-generation" value="create-tables"/>
<property name="eclipselink.ddl-generation.output-mode" value="database"/>
</properties>
</persistence-unit>
</persistence>
Exception [EclipseLink-23004] (Eclipse Persistence Services - 1.1.2.v20090612-r4475): org.eclipse.persistence.exceptions.TransactionException
Exception Description: Error obtaining the Transaction Manager
Internal Exception: Exception [EclipseLink-23001] (Eclipse Persistence Services - 1.1.2.v20090612-r4475): org.eclipse.persistence.exceptions.TransactionException
Exception Description: Error looking up external Transaction resource under JNDI name [weblogic.transaction.TransactionManager]
Internal Exception: javax.naming.NoInitialContextException: Need to specify class name in environment or system property, or as an applet parameter, or in an application resource file: java.naming.factory.initial
at org.eclipse.persistence.exceptions.TransactionException.errorObtainingTransactionManager(TransactionException.java:125)
at org.eclipse.persistence.transaction.JTATransactionController.<init>(JTATransactionController.java:64)
at org.eclipse.persistence.transaction.wls.WebLogicTransactionController.<init>(WebLogicTransactionController.java:27)
MJ
FUDForum. Page generated in 0.03250 seconds
