Home » Language IDEs » Java Development Tools (JDT) » Java Build Path: Diff between Add Jars, Add External Jars, Add Library ?
Java Build Path: Diff between Add Jars, Add External Jars, Add Library ? [message #510987] Fri, 29 January 2010 08:02 Go to next message
When I setup in a Project Properties the Java Build Path->"Libraries" tab then there are
a couple of buttons to add *.jar files:
Add Jars,
Add External Jars,
Add Library->User Library
What are the differences ?
From my point of view all 3 are suitable to add *.jars
Assume the result of the current project should be a project.jar
How do I distinguish between existing *.jar libraries which should be physically
added/embedded/included (later) into this build project.jar and those *.jar libaries
which should only be referenced (during compile) but NOT added physically?
[Updated on: Fri, 29 January 2010 08:05] by Moderator
Re: Java Build Path: Diff between Add Jars, Add External Jars, Add Library ? [message #511664 is a reply to message #510987] Tue, 02 February 2010 08:26 Go to previous message
Ben wrote:
> When I setup in a Project Properties the Java Build Path then there are
> Add Jars, Add External Jars, Add Library->User Library
Press F1 for help ;-)
Dani
> physically
> *.jar libaries
> physically?
Previous Topic:Refactoring of code on Eclipse?
Next Topic:How to open Java Editor
Current Time: Sun Jul 20 15:56:33 EDT 2025
Powered by FUDForum. Page generated in 0.07648 seconds
