Home » Eclipse Projects » Plugin Development Environment (PDE) » Load Native Library
Load Native Library [message #510828] Thu, 28 January 2010 13:34
Hi everyone, I'm developing a Eclipse plugin that uses a Java3D which requires a native library to run. During development I figured out to work with these native libraries by using the -Djava.library.path=${project_loc}/native command that refers to the folder where the libraries are. Now I want to be able to build the plugin and install it as an update site without needing the users to download and install Java3D by their own means.
I've found something about Bundle-Nativecode but I'm not sure if that is the way, because in the SWT jar (org.eclipse.swt.gtk.linux.x86_3.5.1.v3555a.jar) I look for the mentioned line in the manifest file, but can't find anything like that.
Now the question what is the correct way to do that??
Thanks in advance
Previous Topic:dependent plugin XML schema loading
Next Topic:Load Native Library
Current Time: Sat Jul 19 11:34:59 EDT 2025
Powered by FUDForum. Page generated in 0.03129 seconds
