Home » Modeling » GMF (Graphical Modeling Framework) » GMF Editor resolving SVG-Images to Resource
GMF Editor resolving SVG-Images to Resource [message #510655] Thu, 28 January 2010 04:23 Go to next message
I got some questions about svg images and a gmf editor. when i am importing a svg file to a gmf editor,
I need to edit an svg image and set some more properties and export is as an *.[itsmyextension].
-How looks the (java/gmf) Resource of an SVG-Image (org.eclipse.gmf.runtime.emf.core.resources). In other word, is the resource relevant, or is gmf managing this by its own and i don´t have to do anything with resources?
-Do i am able to edit elements of the image alone, or i am able to edit the image as one? (Edit a rect, circle, g-elements within an image?)
GMF uses batik, am i able to "split" an image to its simple svg elements?
Is GMF able to generate an editor with this functionality, or do i have to change generated code? (i think i have to change some code, but i want to generate the most).
What i am able to generate? Is this theoretical possible to do? I don´t want a java-code-solution...
Re: GMF Editor resolving SVG-Images to Resource [message #510667 is a reply to message #510655] Thu, 28 January 2010 05:05 Go to previous messageGo to next message
a basci support of SVG image exist in GMF experimental SDK. But I don't know how it works. I just use it to display it. No modifications on it.
Perhaps you can take a look.
Regards.
Re: GMF Editor resolving SVG-Images to Resource [message #510712 is a reply to message #510655] Thu, 28 January 2010 07:08 Go to previous message
Yes i do. I am not able to do it now, because i have not the time, so i ask it. I knew the basic support, and it works fine for me. But i have not tested or checked svg modification and how a svg pictures resource looks like.
Previous Topic:EditPolicy installed by parent of AffixedChild or ExternalLabel
Next Topic:GMF Compartments
Current Time: Sat Jul 19 20:07:07 EDT 2025
Powered by FUDForum. Page generated in 0.02961 seconds
