Home » Eclipse Projects » JFace » Realm object problem while trying to create WritableList from two threads
Realm object problem while trying to create WritableList from two threads [message #510101] Tue, 26 January 2010 09:39 Go to next message
Originally posted by: fxulusoy.yahoo.com
I am using table view to show some model elements and I am using EMF
databinding. This is my input setting method for table view. (My
application is a RAP application.)
private void setInput() {
List<? extends UnicaseModelElement> taskItems = null;
if (getCurrProject() != null) {
taskItems = getCurrProject().getAllModelElementsbyClass(
TaskPackage.eINSTANCE.getCheckable(),
new BasicEList<UnicaseModelElement>());
WritableList emfList = new WritableList(Realm.getDefault(),
taskItems, UnicaseModelElement.class);
tableViewer.setInput(emfList);
tableViewer.refresh();
Data that I show in the view is actually stored in the server and I have
local copy. I have extra thread which is polling the server to get
updates. When the updater thread gets changes from server, it calls a
listener methods to apply changes on the view. Like that:
public void notify(Notification notification, Project project,
ModelElement modelElement) {
setInput();
By the way, I am new in EMF and EMF-databinding. From my point of
understanding, accesing from different threads causes problem because
observables can only be accessed from one realm. My updater has no
relation with IObservable so it doesn't have realm.
After some tries I always get these exceptions:
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
This operation must be run within the observable's realm
or
....Realm can't be null...
How can I handle this problem?
Thanks.
Re: Realm object problem while trying to create WritableList from two threads [message #510281 is a reply to message #510101] Tue, 26 January 2010 19:28 Go to previous messageGo to next message
Use Realm.asyncExec(Runnable):
writableList.getRealm().asyncExec(new Runnable() {
public void run() {
// apply list changes here
If you're getting the error "Realm can't be null" it's because there is
no default realm set on the thread you're creating the WritableList
from--you can either embed your main block in a
Realm.runWithDefault(Realm, Runnable) and create the WritableList inside
the runnable, or you can just explicitly pass the realm to the WritableList.
Hope this helps,
Matthew
> WritableList(Realm.getDefault(), taskItems,
> setInput();
> or
> Thanks.
Re: Realm object problem while trying to create WritableList from two threads [message #510332 is a reply to message #510281] Wed, 27 January 2010 05:00 Go to previous messageGo to next message
Hi Matthew,
I had tried that before. It didn't help. I tried it again after your
e-mail. It works partially. I don't get exceptions related with realm
but I get swt exception when I was refreshing the table.
Here is my changed code:
final WritableList list = (WritableList) (tableViewer.getInput());
if (list != null) {
list.getRealm().asyncExec(new Runnable() {
public void run() {
list.retainAll(new
list.addAll(taskItems);
} else {
When I remove the refreshing into run method, this time the view is not
refreshed. But, the input was set correctly. If I make any user
interaction on the view like clicking somewhere on the view. Then, I can
see the changes on the view.
This is the exception that I get.
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2687)
at org.eclipse.swt.SWT.error(SWT.java:2607)
at org.eclipse.swt.SWT.error(SWT.java:2578)
at org.eclipse.swt.widgets.Widget.error(Widget.java:892)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:825)
at org.eclipse.swt.widgets.Table.deselectAll(Table.java:1487)
at
org.eclipse.jface.viewers.TableViewer.doDeselectAll(TableVie wer.java:270)
at
org.eclipse.jface.viewers.AbstractTableViewer.setSelectionTo Widget(AbstractTableViewer.java:867)
at
org.eclipse.jface.viewers.StructuredViewer.setSelectionToWid get(StructuredViewer.java:1685)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1375)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1331)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1431)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:539)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1390)
at org.unicase.ui.web.tabs.TaskItemsTab.setInput(TaskItemsTab.j ava:156)
at org.unicase.ui.web.tabs.TaskItemsTab.updateInput(TaskItemsTa b.java:440)
at org.unicase.ui.web.tabs.TaskItemsTab.notify(TaskItemsTab.jav a:421)
at org.unicase.metamodel.impl.ProjectImpl$2.run(ProjectImpl.jav a:411)
at
org.unicase.metamodel.impl.ProjectImpl.notifyProjectChangeOb servers(ProjectImpl.java:353)
at
org.unicase.metamodel.impl.ProjectImpl.handleEMFNotification (ProjectImpl.java:414)
at
org.unicase.metamodel.util.ProjectChangeNotifier.fireNotific ation(ProjectChangeNotifier.java:121)
at
org.unicase.metamodel.util.ProjectChangeNotifier.notifyChang ed(ProjectChangeNotifier.java:90)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:280)
at
org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch (NotificationImpl.java:1033)
at
org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch (NotificationImpl.java:1038)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:468)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:406)
at org.eclipse.emf.common.util.AbstractEList.addAll(AbstractELi st.java:374)
at
org.unicase.emfstore.esmodel.versioning.operations.impl.Mult iReferenceOperationImpl.apply(MultiReferenceOperationImpl.ja va:334)
at
org.unicase.workspace.impl.ProjectSpaceImpl.applyOperations( ProjectSpaceImpl.java:2324)
at
org.unicase.workspace.impl.ProjectSpaceImpl.update(ProjectSp aceImpl.java:1350)
at
org.unicase.web.updater.UpdateProjectHandler$2.doExecute(Upd ateProjectHandler.java:162)
at
org.eclipse.emf.transaction.RecordingCommand.execute(Recordi ngCommand.java:135)
at
org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:84)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.basicExecute(AbstractTransactionalCommandStack.java:2 41)
at
org.eclipse.emf.transaction.impl.TransactionalCommandStackIm pl.doExecute(TransactionalCommandStackImpl.java:63)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:165)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:219)
at
org.unicase.web.updater.UpdateProjectHandler.update(UpdatePr ojectHandler.java:156)
at
org.unicase.web.updater.UpdateProjectHandler.run(UpdateProje ctHandler.java:112)
> public void run() {
> WritableList.
> Hope this helps,
> Matthew
>> private void setInput() { List<? extends
>> have local copy. I have extra thread which is polling the server to
>> get updates. When the updater thread gets changes from server, it
>> calls a listener methods to apply changes on the view. Like that:
>> setInput();
>> or
>> Thanks.
Re: Realm object problem while trying to create WritableList from two threads [message #510599 is a reply to message #510332] Wed, 27 January 2010 17:34 Go to previous messageGo to next message
Hi Matthew,
I have solved the problem. The solution is here:
http://wiki.eclipse.org/index.php/5._Display.#Multithreaded_ Programming
Thank you very much Matthew.
Best Regards.
Fatih Ulusoy wrote:
> Hi Matthew,
> if (list != null) {
> public void run() {
> list.retainAll(new
> } else {
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> public void run() {
>> is no default realm set on the thread you're creating the WritableList
>> inside the runnable, or you can just explicitly pass the realm to the
>> WritableList.
>> Hope this helps,
>> Matthew
>>> setInput();
>>> or
>>> Thanks.
Re: Realm object problem while trying to create WritableList from two threads [message #510630 is a reply to message #510599] Thu, 28 January 2010 01:02 Go to previous message
Part of the problem is that your viewer input observable needs to belong
to the display realm.
The idiomatic way to address multi-threading problems like this in data
binding is to create an observable list in the worker thread, and
another in the display thread, and then bind the two lists to eachother
to bridge between threads. This is exactly the problem that realms were
introduced to solve:
IObservableList workerList = new WritableList(workerRealm);
IObservableList displayList = new WritableList(displayRealm);
bindingContext.bindList(displayList, workerList);
Now you can make changes to workerList and the changes will be
automatically synchronized to the viewer on the display thread.
Matthew
Previous Topic:cut-n-paste from TreeViewer??? or something similar???
Next Topic:Why must press "Enter" for ComboBoxCellEditor?
Current Time: Sat Jul 19 06:23:24 EDT 2025
Powered by FUDForum. Page generated in 0.03919 seconds
