Home » Modeling » M2T (model-to-text transformation) » [Xpand] Referenced model unaccessible
[Xpand] Referenced model unaccessible [message #510346] Wed, 27 January 2010 05:29 Go to next message
I try to prettyprint a model that refers to another model.
In my metamodel there is a class named AtomicProposition that has a reference to another metamodel of type Variable that has an attribute name.
The rules for prettyprinting these modelelements are as follows:
«DEFINE generatePathFormula FOR AtomicProposition»«EXPAND generateVariable FOR this.Variable»«ENDDEFINE»
«DEFINE generateVariable FOR Variable»«this.name»«ENDDEFINE»
Both metamodels are imported in the template.
When I execute my template using a workflow, nothing is generated for the variable.
However, when I replace in the generateVariable definition:
«this.name»
by
«this.toString()»
I get the following output for the variable:
slco.impl.VariableImpl@a084f8 (eProxyURI: LegoCase-plain.slco#//@classes.3/@stateMachines.1/@variables.0)
It appears to me that the variable can be found, but the name cannot be printed.
Does anybody have an idea what my problem could be?
Re: [Xpand] Referenced model unaccessible [message #510455 is a reply to message #510346] Wed, 27 January 2010 10:00 Go to previous messageGo to next message
You have an unresolved proxy.
Somehow the URI
'LegoCase-plain.slco#//@classes.3/@stateMachines.1/@variable s.0' cannot
be resolved. Is LegoCase-plain-slco laying next to the resource at hand?
Sven
Marcel schrieb:
> Hello,
> the variable.
> «this.name»
> by
> «this.toString()»
> LegoCase-plain.slco#//@classes.3/@stateMachines.1/@variables .0)
> printed.
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xpand] Referenced model unaccessible [message #510651 is a reply to message #510455] Thu, 28 January 2010 03:58 Go to previous messageGo to next message
Hello Sven,
Yes, both models are in the same folder.
Could it maybe have to do with the workflow I am using, it is as follows:
<workflow>
  <property name="model" value="My.temporallogic"/>
  <property name="targetdir" value="src-gen"/>
  <component class="org.eclipse.emf.mwe.utils.Reader">
    <uri value="src/${model}"/>
    <modelSlot value="LTLFormula"/>
  </component>
  <component class='org.eclipse.xpand2.Generator'>
    <metaModel id="temporallogic" class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
      <metaModelPackage value="temporallogic.TemporallogicPackage"/>
    </metaModel>
    <metaModel id="slco" class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
      <metaModelPackage value="slco.SlcoPackage"/>
    </metaModel>
    <expand value='template::TemporalLogicPrettyPrinter::prettyPrint FOR LTLFormula'/>
    <genPath value='${targetdir}'/>
  </component>
</workflow>
Marcel
Re: [Xpand] Referenced model unaccessible [message #510776 is a reply to message #510651] Thu, 28 January 2010 10:27 Go to previous messageGo to next message
It is maybe enough to prefix the URI with the right scheme.
Please try 'file:/./src/${model}'.
Sven
Marcel schrieb:
> Hello Sven,
> <workflow>
> </component>
> </metaModel>
> </metaModel>
> LTLFormula'/>
> </component>
> </workflow>
> Regards,
> Marcel
Re: [Xpand] Referenced model unaccessible [message #511341 is a reply to message #510776] Mon, 01 February 2010 05:59 Go to previous message
Hello Sven,
Thank you for your answer. Inserting the absolute path solved my problem.
However, I am not the only one using this transformation and you can imagine that tehe other users may have a different directory lay-out on their hard drives. This means that they would have to change the workflow in to use this transformation.
Are there other ways to solve my problem?
Marcel
[Updated on: Mon, 01 February 2010 06:00] by Moderator
Previous Topic:Xpand vs Acceleo vs JET
Next Topic:[Acceleo] Inconsistent Line Ending Style
Current Time: Sat Jul 19 16:33:05 EDT 2025
Powered by FUDForum. Page generated in 0.35830 seconds
