Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] junit tests in headless buckminster
Re: [buckminster-dev] junit tests in headless buckminster [message #510000] Mon, 25 January 2010 19:48
Searching for such a feature or plugin on the buckminster update site,
the best I can find in ~/downloads/tools/buckminster is:
$ find . -maxdepth 3 -type f -name org.eclipse.buckminster.junit.\*.jar
../updates-3.6/plugins/org.eclipse.buckminster.junit.source_ 1.0.0.r11055.jar
../updates-helios/plugins/org.eclipse.buckminster.junit.sour ce_1.0.0.r11055.jar
../headless-3.6/plugins/org.eclipse.buckminster.junit.source _1.0.0.r11055.jar
Is this feature being built and published?
N
On Mon, Jan 25, 2010 at 12:30 PM, Cailliau, Dieter
<dieter.cailliau@barco.com> wrote:
> I need an archived update site (containing the org.eclipse.buckminster.junit.feature.feature.group ? )
> This is not mentioned on this page: http://www.eclipse.org/buckminster/downloads.html
> so i don't know where to find it.
> -----Original Message-----
> From: buckminster-dev-bounces@eclipse.org on behalf of Achim Demelt
> Sent: Mon 25/01/2010 18:14
> To: Buckminster developer discussions
> Subject: Re: [buckminster-dev] junit tests in headless buckminster
> Hi Dieter,
> The Buckminster JUnit and EclEmma code has been committed to the Buckminster
> repository at eclipse.org. You can find the features on our regular p2 sites,
> i.e. the ones you're using anyway to install (headless) Buckminster.
> Cheers,
>  Achim
> On Monday 25 January 2010 18:03:26 Cailliau, Dieter wrote:
>> I was wondering how to integrate my junit tests in the headless build
>>  procedure. Is this still up to date:
>>  http://code.google.com/p/buckminster-contrib/wiki/Buckmins terJUnit ? If i
>>  do so, it stops with a NullPointerException:
>> x@x:/usr/local/hbm$ ./buckminster -data /tmp/x1 -L DEBUG -consoleLog junit
>>  -l /plugins/com.x.util/src-test.launch !SESSION 2010-01-25 19:50:18.752
>>  ----------------------------------------------- eclipse.buildId=unknown
>> java.version=1.5.0_14
>> java.vendor=Sun Microsystems Inc.
>> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
>> Framework arguments:  -L DEBUG junit -l /plugins/com.x.util/src-test.launch
>> Command-line arguments:  -data /tmp/x1 -L DEBUG -consoleLog junit -l
>> !ENTRY org.eclipse.buckminster.runtime 0 293 2010-01-25 19:50:22.546
>> !MESSAGE junit '-l' '/plugins/com.x.util/src-test.launch'
>> java.lang.NullPointerException
>> DISCLAIMER:
>> Unless indicated otherwise, the information contained in this message is
>>  privileged and confidential, and is intended only for the use of the
>>  addressee(s) named above and others who have been specifically authorized
>>  to receive it. If you are not the intended recipient, you are hereby
>>  notified that any dissemination, distribution or copying of this message
>>  and/or attachments is strictly prohibited. The company accepts no
>>  liability for any damage caused by any virus transmitted by this email.
>>  Furthermore, the company does not warrant a proper and complete
>>  transmission of this information, nor does it accept liability for any
>>  delays. If you have received this message in error, please contact the
>>  sender and delete the message. Thank you.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
> DISCLAIMER:
> Unless indicated otherwise, the information contained in this message is privileged and confidential, and is intended only for the use of the addressee(s) named above and others who have been specifically authorized to receive it. If you are not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message and/or attachments is strictly prohibited. The company accepts no liability for any damage caused by any virus transmitted by this email. Furthermore, the company does not warrant a proper and complete transmission of this information, nor does it accept liability for any delays. If you have received this message in error, please contact the sender and delete the message. Thank you.
Nick Boldt :: JBoss by Red Hat
Productization Lead :: JBoss Tools & Dev Studio
Release Engineer :: Dash Athena
http://nick.divbyzero.com
Previous Topic:RE: [buckminster-dev] junit tests in headless buckminster
Next Topic:Re: [buckminster-dev] junit tests in headless buckminster
Current Time: Sun Jul 20 10:54:42 EDT 2025
Powered by FUDForum. Page generated in 0.03042 seconds
