EMF's OSGI Configuration [message #509840] |
Mon, 25 January 2010 09:57  |
Originally posted by: jseng.valen.trick.gov
I have a simple EMF project from schema. I added all the appropriate jars
to the classpath. This is embedded as a plugin into a closed-source
toolkit. The program worked fine.
I did an upgrade of the closed-source toolkit. They apparently fixed a
bug that allowed classes on the classpath to be used, requiring proper
OSGI configuration. This is where the problems start.
Previously, I had only needed a few jars for EMF to work:
* org.eclipse.emf_2.5.0.v200906151043.jar
* org.eclipse.emf.common_2.5.0.v200906151043.jar
* org.eclipse.emf.ecore_2.5.0.v200906151043.jar
and maybe 1 or 2 more.
Now, the OSGI configurations are requiring others which require others and
I just cannot find enough jars to make it run.
All of this starts from the MANIFEST.MF generated by EMF which has the
following:
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.eclipse.emf.ecore.xmi;visibility:=reexport
Bundle-ActivationPolicy: lazy
Is there a complete package of jar files (OSGI speaking) for EMF?
Thank you,
Jonathan
Re: EMF's OSGI Configuration [message #509914 is a reply to message #509840] |
Mon, 25 January 2010 13:39  |
Jonathan,
Comments below.
> following:
That really depends on the dependencies of org.eclipse.org.runtime. The
Plug-in Dependencies "folder" of the project in the Package Explorer
shows this type of information.
> Thank you,
> Jonathan
FUDForum. Page generated in 0.03589 seconds
