Home » Archived » Test and Performance Tools Platform (TPTP) » cxxTest dependencies(testing, cxxtest)
cxxTest dependencies [message #509492] Fri, 22 January 2010 10:26 Go to next message
I'm new to this forum, hope this is the right place to be posting this.
I'm having a problem with the cxxTest plugin for eclipse. I install it and I can write test functions and get the runner to create a test harness.
The problems come when I attempt to generate stack traces for test failures and memory leaks. This option is in the Window->Preferences->cxxtest tab.
I click this on to get the test to run and trace the output but eclipse shows this message:
"Looking for required cxxTest dependencies"
then
"In order to support retreiving stack traces when failures occur in cxxtest unit tests, the following dependencies need to be intalled on youtr system:
* The following linker libraries are missing: libbfd, libintl, libiberty
Stack traces will be disabled in any projects that you create. Once you have satisfied these requirements, you can re-enable this feature in your eclipse preferences."
How do I 'Satisfy these requirements' ?
Chris.
Re: cxxTest dependencies [message #509799 is a reply to message #509492] Mon, 25 January 2010 07:27 Go to previous messageGo to next message
Sorry Chris,
This is the wrong forum.
Paul
<knightstreet@yahoo.com> wrote in message
news:hjcg3k$ip9$1@build.eclipse.org...
> shows this message:
> Quote:
> then
> Quote:
>> youtr system:
> Chris.
Re: cxxTest dependencies [message #545331 is a reply to message #509799] Wed, 07 July 2010 09:07 Go to previous messageGo to next message
Which would be the right one?
M
Re: cxxTest dependencies [message #729733 is a reply to message #509492] Mon, 26 September 2011 17:11 Go to previous messageGo to next message
Did you ever figure this out? Please share the solution if you did.
Re: cxxTest dependencies [message #729867 is a reply to message #729733] Tue, 27 September 2011 02:57 Go to previous message
The cxxTest stuff seems to originate at web-cat.org.
<http://web-cat.org/WCWiki/EclipsePlugins/CxxTestPlugin>
It is definitely not related to TPTP.
Maybe the bugtracker of WEB-CAT ist the right place to go:
<http://sourceforge.net/tracker/?group_id=142064&atid=754973>
Hope this helps (a bit),
Heiner
Previous Topic:How to export Trace Interaction / Sequence Diagram?
Next Topic:Local memory profiling of a 32-bit Eclipse application from a 64-bit workbench (Windows)
Current Time: Sat Jul 19 15:59:18 EDT 2025
Powered by FUDForum. Page generated in 0.03124 seconds
