Home » Modeling » EMF » [CDO Teneo] Cannot start a CDO Server with a Hibernate Datastore using a Derby Database
[CDO Teneo] Cannot start a CDO Server with a Hibernate Datastore using a Derby Database [message #509758] Mon, 25 January 2010 05:29 Go to next message
I would need some help with a problem. When I start up a CDO server using a
Hibernate Datastore and a Derby database the server exit with a
SQLGrammarException exception:
[QUOTE]
create table cdo_package_unit (nsUri varchar(255) not null, originalType
varchar(255) for bit data, timeStamp bigint, EPackageBlob varchar(40000) for
bit data, primary key (nsUri))
alter table cdo_package_info add constraint FK5702C978798F06A8 foreign key
(cdo_package_unit_id) references cdo_package_unit
!ENTRY org.eclipse.emf.cdo.server 1 0 2010-01-22 12:00:51.392
!MESSAGE No user manager configured. Users will not be authenticated
org.hibernate.exception.SQLGrammarException: could not load an entity:
[CDOPackageUnit#http://www.eclipse.org/emf/2002/Ecore]
[UNQUOTE]
See also attached file Stacktrace.txt
Cheers
Bjoern
Re: [CDO Teneo] Cannot start a CDO Server with a Hibernate Datastore using a Derby Database [message #509777 is a reply to message #509758] Mon, 25 January 2010 06:25 Go to previous message
Hi Bjoern,
Found the issue, to store CDO epackage information a table cdo_package_unit is created which has a field epackageblob
which has a length of 40000. Hibernate maps this field to varchar in Derby (and to a blob in mysql which is better). In
Derby varchars have a max length of 32kb. Setting the max length to 32700 solves it.
I entered a bugzilla for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=300621
I will maybe change the mapping of this field so that the length does not need to be supplied.
gr. Martin
> [QUOTE]
> [UNQUOTE]
> Cheers
> Bjoern
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:[CDO Teneo] Hibernate Store standalone server example?
Next Topic:[CDO Teneo] Problem mapping an EJavaObject using a CDO Server with a Hibernate Datastore
Current Time: Sun Jul 20 16:16:18 EDT 2025
Powered by FUDForum. Page generated in 0.04174 seconds
