Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Best way to embed Links in Text
Best way to embed Links in Text [message #509324] Thu, 21 January 2010 18:30 Go to next message
Hello Group,
I am trying to implement special URI presentation for a chatprogram in
SWT using StyledText.
Problem is the following ...
Requirement 1:
Links should be clickable (Browser should open.. in short need a
backcall when the links is clicked)
2. Links might need a presentation in a more readable format ... some
special URI should be presented with a human readable text instead of
the pure URI.
3. When text is selected and copied the URI should be in the clipboard.
1 is simple to get..
So far I tried using StyleRanges to colour the URI. But that does not
make the replacement with readable text possible.
I also tried embedding a Link widget in the StyledText. Which makes
replacement with readable text easy. This seemed ideal as one could lay
the Link widget with the readable text directly over the URI in the
text, resulting on text marked that the URI was copied.
Though that didn't work too well. GlyphMetrics seems to be inaccurate
with multiple characters. As one can only give the width per character a
control spanning over several charadcters will allways fail to be the
same length as the URI. so with embedding controls its important to have
only one character below the control. Though with one character below
Link widget, on copying, the URI is not in the clipboard.
Anyone got an idea what I could do? Any good/siomple solution that I
miss to see?
regards
Christian
Re: Best way to embed Links in Text [message #509528 is a reply to message #509324] Fri, 22 January 2010 12:08 Go to previous messageGo to next message
Hi Christian,
Note that as of eclipse/swt 3.5, StyledText has support for specifying a
block of text as a Link, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=83408 . Using this should
ensure that your links appear/behave properly.
Regarding changing a link text to a url when copied to the clipboard, there
isn't a way to make this just happen. You'll need to implement your own
copy functionality which takes a copy of the StyledText's content, does the
necessary link name -> url changes, and writes the content to the clipboard.
Whether you're able to get in the way of the StyledText's copy functionality
depends on your context (eg.- perhaps adding a SWT.KeyDown filter to the
Display and looking for the platform-specific Copy shortcut? Or if you're
defining a view, does eclipse send some sort of "do copy" notification to
your view when triggered by the user?).
For info about using the Clipboard see:
http://www.eclipse.org/articles/Article-SWT-DND/DND-in-SWT.h tml
http://www.eclipse.org/swt/snippets#clipboard
swt's ClipboardExample in http://www.eclipse.org/swt/examples.php
HTH,
Grant
"Christian" <fakemail@xyz.de> wrote in message
news:hjao28$ev1$1@build.eclipse.org...
> Hello Group,
> Requirement 1:
> the pure URI.
> miss to see?
> regards
> Christian
Re: Best way to embed Links in Text [message #509585 is a reply to message #509528] Sat, 23 January 2010 05:53 Go to previous message
Am 22.01.2010 18:08, schrieb Grant Gayed:
I am using eclipse's build in copy command (org.eclipse.ui.edit.copy) to
copy text assuming it just uses the copy() method of styled text for
copying text to the clipboard.
So I probably should just overwrite that copy() method. Though have to
check this.
Christian
Previous Topic:Developing on Windows, Running on OS X, Help!
Next Topic:Using EMF+ with SWT
Current Time: Sat Jul 19 08:17:26 EDT 2025
Powered by FUDForum. Page generated in 0.04399 seconds
