Home » Archived » BIRT » I can't debug my birt report!
I can't debug my birt report! [message #508430] |
Mon, 18 January 2010 13:16  |
Originally posted by: rodrigo.garcia.kotasoft.com
I'm new with birt. I'have followed all tutorials that I've found and now
I'm trying to develop my report, but it's very difficult for me to do it
because I can't use the debug mode. When I launch the debug mode,
eclipse doesn't open the debug perspective and doesn't stop in the
breakpoints.
I'm working with scripted datasources and I've tried with both
javascript event handlers and java event handlers.
Any idea?
Thank you in advance.
Re: I can't debug my birt report! [message #509406 is a reply to message #508920] |
Fri, 22 January 2010 01:46   |
Yes, I have watched the video, and yes, I'm trying 2.5.1.
I'm using eclipse rcp galileo with birt 2.5.1 for linux gtk x86_64, and
I have also tried with the birt distribution.
is that a possible bug or am I doing something wrong? I'll ask to some
mate to try it to see if he has the same problem.
I have downloaded the birt report samples from the cvs to check if I
have the same problem.
I'll let you know if I have news
thanks
Jason Weathersby escribió:
> Rodrigo,
> Did you watch the video? Also can you try 2.5.1?
> Jason
> Rodrigo García wrote:
>> Yes,
>> I have breakpionts set in my scripts.
>> I'm using birt 2.5
>>> Rodrigo,
>>> I assume you have breakpoints set in the script?
>>> This video shows 2.3 features as well as the debugger.
>>> http://live.eclipse.org/node/484
>>> Jason
>>>> Hi Jason,
>>>> This is the I was trying to debug my report. I have a report debug
>>>> configurarion with the javascript radio button selected.
>>>> Any other idea?
>>>> Thank you.
>>>>> Rodrigo,
>>>>> Can you select the debug perspective and click on the report icon
>>>>> and create a new report debug configuration? It should
>>>>> automatically choose your report to debug. Make sure the
>>>>> JavaScript radial is selected.
>>>>> Jason
>>>>>> I have had success debugging my java event handlers but not with
>>>>>> my javscript event handlers
>>>>>> Any idea?
>>>>>> Rodrigo García escribió:
>>>>>>> Hi,
>>>>>>> and now I'm trying to develop my report, but it's very difficult
>>>>>>> for me to do it because I can't use the debug mode. When I launch
>>>>>>> the debug mode, eclipse doesn't open the debug perspective and
>>>>>>> doesn't stop in the breakpoints.
>>>>>>> Any idea?
Re: I can't debug my birt report! [message #509516 is a reply to message #509406] |
Fri, 22 January 2010 06:46   |
Rodrigo,
Please post your findings. I can not reproduce the issue you are having.
Jason
> thanks
>> Rodrigo,
>> Jason
>>> Yes,
>>> I'm using birt 2.5
>>>> Rodrigo,
>>>> Jason
>>>>> Hi Jason,
>>>>> Any other idea?
>>>>> Thank you.
>>>>>> Rodrigo,
>>>>>> Jason
>>>>>>> Any idea?
>>>>>>>> Hi,
>>>>>>>> launch the debug mode, eclipse doesn't open the debug
>>>>>>>> perspective and doesn't stop in the breakpoints.
>>>>>>>> Any idea?
Re: I can't debug my birt report! [message #509802 is a reply to message #509516] |
Mon, 25 January 2010 07:42   |
Hi Jason,
One of my mates has tried to debug a sample report with scripting
datasource having the same result as me. The debugger doesn't stop at
breakpoints.
Both we have eclipse galileo rcp sr1 for ubuntu gtk x86_64
We have downloaded the plugin
org.eclipse.birt.report.designer.samplereports and I have tried with
ScriptedDatasourceExampleAfter.rptdesign
> Rodrigo,
> Thanks
> Jason
>> Hi,
>> and I have also tried with the birt distribution.
>> thanks
>>> Rodrigo,
>>> Jason
>>>> Yes,
>>>> I'm using birt 2.5
>>>>> Rodrigo,
>>>>> Jason
>>>>>> Hi Jason,
>>>>>> Any other idea?
>>>>>> Thank you.
>>>>>>> Rodrigo,
>>>>>>> Jason
>>>>>>>> Any idea?
>>>>>>>>> Hi,
>>>>>>>>> found and now I'm trying to develop my report, but it's very
>>>>>>>>> difficult for me to do it because I can't use the debug mode.
>>>>>>>>> When I launch the debug mode, eclipse doesn't open the debug
>>>>>>>>> Any idea?
Re: I can't debug my birt report! [message #509830 is a reply to message #509802] |
Mon, 25 January 2010 09:45   |
Rodrigo,
Can you try with a beforeFactory script? I am wondering if it is an
issue with scripted datasources.
Jason
> Hi Jason,
> breakpoints.
>> Rodrigo,
>> Thanks
>> Jason
>>> Hi,
>>> some mate to try it to see if he has the same problem.
>>> thanks
>>>> Rodrigo,
>>>> Jason
>>>>> Yes,
>>>>> I'm using birt 2.5
>>>>>> Rodrigo,
>>>>>> Jason
>>>>>>> Hi Jason,
>>>>>>> debug configurarion with the javascript radio button selected.
>>>>>>> Any other idea?
>>>>>>> Thank you.
>>>>>>>> Rodrigo,
>>>>>>>> icon and create a new report debug configuration? It should
>>>>>>>> Jason
>>>>>>>>> with my javscript event handlers
>>>>>>>>> Any idea?
>>>>>>>>>> Hi,
>>>>>>>>>> Any idea?
Re: I can't debug my birt report! [message #509857 is a reply to message #509830] |
Mon, 25 January 2010 10:44  |
Hi Jason,
You're right, it seems an issue with scripted datasources, the debugger
stops at breakpoints in report event scripts like initialize and
beforeFactory...
> Rodrigo,
> Jason
>> Hi Jason,
>> breakpoints.
>>> Rodrigo,
>>> having.
>>> Thanks
>>> Jason
>>>> Hi,
>>>> thanks
>>>>> Rodrigo,
>>>>> Jason
>>>>>> Yes,
>>>>>> I'm using birt 2.5
>>>>>>> Rodrigo,
>>>>>>> Jason
>>>>>>>> Hi Jason,
>>>>>>>> Any other idea?
>>>>>>>> Thank you.
>>>>>>>>> Rodrigo,
>>>>>>>>> Jason
>>>>>>>>>> Any idea?
>>>>>>>>>>> Hi,
>>>>>>>>>>> both javascript event handlers and java event handlers.
>>>>>>>>>>> Any idea?
Re: I can't debug my birt report! [message #509873 is a reply to message #509857] |
Mon, 25 January 2010 06:16  |
Rodrigo,
I just checked 2.5.1 and the problem is there as well.
I also found a bug already logged for it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247938
You may want to implement it in Java if you want to debug it.
Jason
> Hi Jason,
> beforeFactory...
>> Rodrigo,
>> Jason
>>> Hi Jason,
>>> breakpoints.
>>>> Rodrigo,
>>>> having.
>>>> Thanks
>>>> Jason
>>>>> Hi,
>>>>> I have the same problem.
>>>>> thanks
>>>>>> Rodrigo,
>>>>>> Jason
>>>>>>> Yes,
>>>>>>> I'm using birt 2.5
>>>>>>>> Rodrigo,
>>>>>>>> Jason
>>>>>>>>> Hi Jason,
>>>>>>>>> Any other idea?
>>>>>>>>> Thank you.
>>>>>>>>>> Rodrigo,
>>>>>>>>>> Jason
>>>>>>>>>>> Any idea?
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> mode. When I launch the debug mode, eclipse doesn't open the
>>>>>>>>>>>> debug perspective and doesn't stop in the breakpoints.
>>>>>>>>>>>> Any idea?
Re: I can't debug my birt report! [message #509882 is a reply to message #509873] |
Mon, 25 January 2010 06:34  |
Ok Jason,
I was already implementing java event handlers cause of this issue but I
wanted to know if I was making a mistake on debugging javascripts or
it was a bug.
Thank you.
> Rodrigo,
> Jason
>> Hi Jason,
>> debugger stops at breakpoints in report event scripts like initialize
>> and beforeFactory...
>>> Rodrigo,
>>> Jason
>>>> Hi Jason,
>>>> at breakpoints.
>>>>> Rodrigo,
>>>>> having.
>>>>> Thanks
>>>>> Jason
>>>>>> Hi,
>>>>>> x86_64, and I have also tried with the birt distribution.
>>>>>> thanks
>>>>>>> Rodrigo,
>>>>>>> Jason
>>>>>>>> Yes,
>>>>>>>> I'm using birt 2.5
>>>>>>>>> Rodrigo,
>>>>>>>>> Jason
>>>>>>>>>> Hi Jason,
>>>>>>>>>> Any other idea?
>>>>>>>>>> Thank you.
>>>>>>>>>>> Rodrigo,
>>>>>>>>>>> Jason
>>>>>>>>>>>> Any idea?
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> very difficult for me to do it because I can't use the
>>>>>>>>>>>>> debug mode. When I launch the debug mode, eclipse doesn't
>>>>>>>>>>>>> breakpoints.
>>>>>>>>>>>>> Any idea?
Current Time: Sat Jul 19 21:33:56 EDT 2025
Powered by FUDForum. Page generated in 0.27891 seconds
