Home » Archived » Buckminster » E [0001] : Unauthorized & E [0001] : java.lang.NumberFormatException(Try to access a rmap at a secure http url)
E [0001] : Unauthorized & E [0001] : java.lang.NumberFormatException [message #509495] Fri, 22 January 2010 10:45 Go to next message
in my CQuery i would like to access a rmap from http...
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="http://my.location/repo/trunk/tests/app1.rmap">
    <cq:rootRequest name="app1.a" componentType="osgi.bundle"/>
</cq:componentQuery>
this will result in the error:
So i've thought i will prefix a (of course valid) login user.
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="http://test:test@my.location/repo/trunk/tests/app1.rmap">
but then i've received the error:
E [0001] : java.lang.NumberFormatException: For input string: "test@my.location": For input string: "test@my.location"
How can i access a rmap from a secure http adress?
Thank U a lot for a possible solution Smile
Matthias
[Updated on: Fri, 22 January 2010 11:31] by Moderator
Re: E [0001] : Unauthorized & E [0001] : java.lang.NumberFormatException [message #509506 is a reply to message #509495] Fri, 22 January 2010 11:09 Go to previous messageGo to next message
Hi Matthias,
This seems to be caused by code in the ECF HttpClientRetrieveFileTransfer class that assumes that a port number should
follow the ':'. Hence, it makes an attempt to parse the password as an integer. I'm CC'in the ecf-dev mailing list. I
guess Buckminster should do something with the URL before passing it to ECF and perhaps they can clarify what the
correct approach should be.
What you report but I don't see when running tests on this is the conversion into a 'mailto:' URL. I wonder if that's my
newsreader that plays a trick on me. Do you see that in your original mail too?
Thomas Hallgren
On 01/22/2010 04:45 PM, Matthias Kappeller wrote:
> <cq:componentQuery
> <cq:componentQuery
> "mailto:test@my.location": For input string: "mailto:test@my.location"
> Thank U a lot for a possible solution :)
> Regards
> Matthias
Re: E [0001] : Unauthorized & E [0001] : java.lang.NumberFormatException [message #509512 is a reply to message #509506] Fri, 22 January 2010 11:36 Go to previous messageGo to next message
Hi Thomas,
also the 'forum engine' gives me a magic to my url Smile
my
will become a '.'
let me try to enter the url once again with some spaces in between:
http:// test : test @ my.location/repo/trunk/tests/app1.rmap
and the error message does not contain the 'mailto:'. It is 'test @ my.location' (without the spaces beside the @).
Matthias
[Updated on: Mon, 25 January 2010 04:15] by Moderator
Re: E [0001] : Unauthorized & E [0001] : java.lang.NumberFormatException [message #509846 is a reply to message #509495] Mon, 25 January 2010 10:30 Go to previous message
This problem has occurred in multiple cases.
So I 've create a BugReport on this, https://bugs.eclipse.org/bugs/show_bug.cgi?id=300689
I've solved this temporarily while I've adjusted org.eclipse.buckminster.core.query.model.ComponentQuery to 'setConnectContext' always to a predefined 'ConnectContextFactory.createUsernamePasswordConnectContext' .
Matthias
Previous Topic:How to move the product into a update site category
Next Topic:Cannot install headless Buckminster 3.5 or features from update site
Current Time: Sat Jul 19 19:32:00 EDT 2025
Powered by FUDForum. Page generated in 0.03517 seconds
