cxxTest dependencies [message #509492] |
Fri, 22 January 2010 10:26  |
I'm new to this forum, hope this is the right place to be posting this.
I'm having a problem with the cxxTest plugin for eclipse. I install it and I can write test functions and get the runner to create a test harness.
The problems come when I attempt to generate stack traces for test failures and memory leaks. This option is in the Window->Preferences->cxxtest tab.
I click this on to get the test to run and trace the output but eclipse shows this message:
Quote: | "Looking for required cxxTest dependencies"
then
Quote: |
"In order to support retreiving stack traces when failures occur in cxxtest unit tests, the following dependencies need to be intalled on youtr system:
* The following linker libraries are missing: libbfd, libintl, libiberty
Stack traces will be disabled in any projects that you create. Once you have satisfied these requirements, you can re-enable this feature in your eclipse preferences."
How do I 'Satisfy these requirements' ?
Chris.
FUDForum. Page generated in 0.09468 seconds
