Home » Modeling » EMF » emf validation question(How to add more validation?)
emf validation question [message #509239] Thu, 21 January 2010 13:30 Go to next message
I have an emf model and editor generated from a wsdl file. I don't see validator code generated except interfaces with comments like:
"This doesn't really do anything, and it's not a real EMF artifact."
The default ValidateAction already does some work. It seems to be using EObjectValidator. I would like to add more validation such as uniqueness of keys.
Should I create a new EValidator and register it or use org.eclipse.emf.validation.constraintProviders extension?
A related question is cell editor validation, for example, I want to prevent duplicate keys from being entered. I am using PropertyEditingSupport. Should I override its getCellEditor method to set my own ICellEditorValidator or there is better way to do it?
Thanks a lot!
John
Re: emf validation question [message #509398 is a reply to message #509239] Fri, 22 January 2010 06:23 Go to previous messageGo to next message
--------------040406030604080506050102
John,
Comments below.
I'm not sure what you're referring to here.
> uniqueness of keys.
If using IDs or EReference.eKeys aren't sufficient you can define your
own constraints in the model and then implement them in the generated
validator:
< http://help.eclipse.org/galil/index.jsp?topic=/org.eclipse.e mf.doc/references/overview/EMF.Validation.html>
It's possible to use the extended validation framework as well; it's not
clear you need that though.
There isn't support within the property descriptors to do this type of
validation, so I suppose you'd need a specialized cell editor for that.
> Thanks a lot!
> John
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
John,<br>
<br>
Comments below.<br>
<br>
John Ye wrote:
<blockquote cite="mid:hja6fb$fvk$1@build.eclipse.org" type="cite">I
validator code generated except interfaces with comments like: <br>
<br>
</blockquote>
I'm not sure what you're referring to here.<br>
<blockquote cite="mid:hja6fb$fvk$1@build.eclipse.org" type="cite"><br>
uniqueness of keys.
<br>
</blockquote>
validator:<a
href=" http://help.eclipse.org/galil/index.jsp?topic=/org.eclipse.e mf.doc/references/overview/EMF.Validation.html"><br>
</a>
<blockquote><a
href=" http://help.eclipse.org/galil/index.jsp?topic=/org.eclipse.e mf.doc/references/overview/EMF.Validation.html"> http://help.eclipse.org/galil/index.jsp?topic=/org.eclipse.e mf.doc/references/overview/EMF.Validation.html</a><br>
</blockquote>
<br>
</blockquote>
not clear you need that though.<br>
set my own ICellEditorValidator or there is better way to do it? <br>
</blockquote>
validation, so I suppose you'd need a specialized cell editor for that.<br>
<blockquote cite="mid:hja6fb$fvk$1@build.eclipse.org" type="cite">Thanks
a lot!
<br>
John
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------040406030604080506050102--
Re: emf validation question [message #509555 is a reply to message #509398] Fri, 22 January 2010 16:36 Go to previous messageGo to next message
Ed,
Thanks for the tips. My ecore model is generated from wsdl, which itself is also generated and the original source doesn't support key and references.
Now I use setID on key attributes and validateAction is able to catch duplicate keys. I don't think composite keys are supported.
I ran into a new problem with implementing IGotoMarker. It seems that the default EValidator.MARKER only provides URI_ATTRIBUTE. How do I look up an EObject based on that information? I tried resource.getEObject, but it did not work.
John
Re: emf validation question [message #509577 is a reply to message #509555] Fri, 22 January 2010 23:13 Go to previous message
EditUIMarkerHelper's getTargetObjects(editingDomain, marker) seems to do the trick of finding the right objects. This saves me a lot of time.
John
Previous Topic:Root class for models?
Next Topic:Get rid of Example EMF Model Creation Wizards
Current Time: Sat Jul 19 10:35:43 EDT 2025
Powered by FUDForum. Page generated in 0.05529 seconds
