Error creating element [message #508962] |
Wed, 20 January 2010 16:28  |
I created a new element, which is actually a SVGFigure, and everything works and generates fine, however, when I try to put this element in my diagram (from toolbar) I get this exception:
!ENTRY org.eclipse.gmf.runtime.diagram.ui 4 4 2010-01-20 22:09:44.890
!MESSAGE execute
!STACK 0
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:519)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:206)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:169)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:156)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTool.java:399)
at org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(AbstractTool.java:411)
at org.eclipse.gmf.runtime.diagram.ui.tools.CreationTool.performCreation(CreationTool.java:133)
at org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTool.java:178)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java:1064)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:263)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouseReleased(DomainEventDispatcher.java:374)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(LightweightSystem.java:538)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:207)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:failed to create a view
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.gmf.runtime.diagram.ui.commands.CreateCommand.doExecuteWithResult(CreateCommand.java:99)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:135)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:511)
... 37 more
Anyone knows what is the cause of this exception?
thanks, Milan
Re: Error creating element [message #508967 is a reply to message #508964] |
Wed, 20 January 2010 17:17   |
Dear Aurelien,
Aurelien Pupier wrote on Wed, 20 January 2010 17:08 | Hi,
I don't know exactly but perhaps you give the wrong path for the SVG, so it can't create the view.
What is sure is that it can't create a view, now in order to know why you may need to step into the createView.
I think that this is not a problem, because I checked the path multiple times and it is O.K. Which createView?
The wierd thing is that I have an Element which creates fine, and this NewElement extends in my model the Element, and when I try to put NewElement in the diagram I get the exception from the first message. However, then when I move any other element in the diagram, the NewElement I created shows but it looks graphically just like the Element ? In addition, when I click save, it is saved fine, but is shown graphically not as NewElement. but as Element, and I also tried to change its figure to some existing (working) non-svg figure, but the exception remains!
The same thing is asked here, but I'm not sure how is it solved.
btw - I taught that I made some mistake, and removed this element completely, from the graph, tooling, map and code, and defined it again...however the exception is the same.
Regrads, Milan
[Updated on: Wed, 20 January 2010 18:45] by Moderator
Re: Error creating element [message #509322 is a reply to message #509204] |
Thu, 21 January 2010 18:20  |
I finally found what is the problem...In class RBPMNVisualIDRegistry, method getNodeVisualID, have following definition:
switch (containerVisualID) {
if (ActivitiesPackage.eINSTANCE.getTask().isSuperTypeOf(
domainElement.eClass())
&& isTask_3004((Task) domainElement)) {
return TaskEditPart.VISUAL_ID;
and then later in this switch it checks for the subclass:
if (TasksPackage.eINSTANCE.getServiceTask().isSuperTypeOf(
domainElement.eClass())) {
return ServiceTaskEditPart.VISUAL_ID;
As is came first to the ServiceTasks' superclass called Task, it checks whether
the element is Task, and as ServiceTask is actually a Task, the TaskEditPart.VISUAL_ID
is returned.
I'm not sure if this is a GMF bug.
Milan
FUDForum. Page generated in 0.06662 seconds
