Home » Language IDEs » Java Development Tools (JDT) » "Source folder is not a Java project" cannot add class(Mercurial and Bitbucket problem)
"Source folder is not a Java project" cannot add class [message #509161] Thu, 21 January 2010 09:47 Go to next message
Upon importing a mercurial project into Eclipse I am unable to add any new java classes to it as I get an "Source folder is not a Java project" error and am unable to add the class to the project.
I have tried importing the mercurial project in two ways. One is to use the mercurial plug-in.
The other way I have tried is to import it into the workspace via the command-line hg command, then create a new java project of the same name as the newly created folder produced by the mercurial sync-thingy. Eclipse then picks this up and creates a java project with the same name as the mercurial project, correct files, etc. The icon has a little 'J' next to it, suggesting that it is indeed a java project and in the project is a "JRE System Library" folder. Yet I still can't add new java class files as I get told it is not a java project by Eclipse.
I think this issue is with Eclipse, although I'm using the mercurial plug-in and bitbucket (bitbucket mailing group suggested I try here).
Any help most appreciated as I need this to work fairly soon!!!
Re: "Source folder is not a Java project" cannot add class [message #509193 is a reply to message #509161] Thu, 21 January 2010 11:04 Go to previous message
Be sure to check the .project and .classpath files into mercurial. These
files define the project as a Java project.
"Thomas" <thomaschristopherking@googlemail.com> wrote in message
news:hj9pen$fan$1@build.eclipse.org...
Previous Topic:Debug JNI & C++ code called from within JAVA application
Next Topic:Can project type be viewed or changed?
Current Time: Sun Jul 20 09:07:06 EDT 2025
Powered by FUDForum. Page generated in 0.24148 seconds
