Home » Eclipse Projects » DTP » OUTPUT parameters represented as INOUT for SQL Stored Procedures.
icon4.gif  OUTPUT parameters represented as INOUT for SQL Stored Procedures. [message #509129] Thu, 21 January 2010 08:18 Go to next message
I have this sql stored procedure
drop procedure "mydb"."allElems"
GO
CREATE PROCEDURE "allElems" (
@id int,@outvalue1 VARCHAR(20) OUTPUT,@outvalue2 decimal OUTPUT
AS
BEGIN
select @outvalue1="id"
FROM "mydb"."de_humanresource"
return 0;
END
when i load it in the Data Sources Explorer and Edit the stored
procedure i end up with this
CREATE PROCEDURE allElems (
IN @RETURN_VALUE INTEGER,
IN @id INTEGER,
INOUT @outvalue1 VARCHAR(20),
INOUT @outvalue2 DECIMAL(18 , 0))
NOT DETERMINISTIC
NO_SQL
BEGIN
return 0;
END
The outcome of which isn't very pleasant. When I use the DTP API to retrieve the Input parameter I get "outValue1" and "outValue2" as input parameters. Now, that isn't what i expect...
Can anyone please advice.
[Updated on: Thu, 21 January 2010 09:32] by Moderator
Re: OUTPUT parameters represented as INOUT for SQL Stored Procedures. [message #510180 is a reply to message #509129] Tue, 26 January 2010 10:57 Go to previous message
What database are you using? Are you using the Generic JDBC connection
profile or one of the more specific ones customized for a particular DBMS?
Ravikanth wrote:
> Hello,
> I have this sql stored procedure Quote:
>> drop procedure "amxbpm"."allElems"
>> GO
>> AS
>> BEGIN
>> FROM "amxbpm"."de_humanresource"
>> return 0; END
> procedure i end up with this Quote:
>> IN @id INTEGER,
>> NOT DETERMINISTIC
>> NO_SQL
>> BEGIN
>> return 0; END
Re: OUTPUT parameters represented as INOUT for SQL Stored Procedures. [message #597094 is a reply to message #509129] Tue, 26 January 2010 10:57 Go to previous message
Ravikanth wrote:
> Hello,
>> GO
>> AS
>> BEGIN
>> return 0; END
>> IN @id INTEGER,
>> NOT DETERMINISTIC
>> NO_SQL
>> BEGIN
>> return 0; END
Previous Topic:extend result browser?
Next Topic:Instead of Trigger Error
Current Time: Sun Jul 20 02:58:20 EDT 2025
Powered by FUDForum. Page generated in 0.03427 seconds
