Home » Modeling » EMF » Make generated EMF classes implement Serializable
Make generated EMF classes implement Serializable [message #509031] Thu, 21 January 2010 03:56 Go to next message
Hi.
I have emf data model and I am using Teneo for persistence. However because I am using JSF for presentation I need to make the generated EMF classes implement Serializable. How can I achieve this?
Thank you!
Re: Make generated EMF classes implement Serializable [message #509039 is a reply to message #509031] Wed, 20 January 2010 23:22 Go to previous messageGo to next message
Hi Svetoslav,
What I do myself is the following (but maybe others have better ideas):
- create an interface which extends both EObject and Serializable
- then in the genmodel in the field, root extends interface, set this interface and then regenerate the classes
Let me know if this works for you.
gr. Martin
Svetoslav wrote:
> Hi.
> Thank you!
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Make generated EMF classes implement Serializable [message #509067 is a reply to message #509039] Thu, 21 January 2010 05:34 Go to previous messageGo to next message
Hi.
Thank you for the quick reply. I have thought of that way but I didn't want to do it like that because Teneo would generate some unnecessary tables in the database and it will cause some overhead. I have read somewhere about Teneo annotations and that I could control the generation of the table that way but it seems too much work to manually add annotations to all the classes.. I have read some JET tutorials and probably I could achieve that by JET but I couldn't find how can I use it along with EMF model generation.
Re: Make generated EMF classes implement Serializable [message #509072 is a reply to message #509067] Thu, 21 January 2010 05:39 Go to previous messageGo to next message
Hi Svetoslav,
Afaics no new tables would be generated in this way. The generated interfaces already extend EObject and Serializable
does not add anything. Let me know what you see happening if it is different.
Yes you can add annotations directly in the model (http://www.elver.org/hibernate/ejb3_format.html), but afaics it is
not needed in this case.
gr. Martin
Svetoslav wrote:
> Hi.
The Netherlands
Re: Make generated EMF classes implement Serializable [message #509095 is a reply to message #509072] Thu, 21 January 2010 06:42 Go to previous message
Hi.
Thank you for the help! The first time I misunderstood you.. I thought that you are suggesting to create a new interface in the model and assign it to ESuper Type to all classes. It works fine the way you told me. Thanks again!
Re: Make generated EMF classes implement Serializable [message #509101 is a reply to message #509072] Thu, 21 January 2010 02:04 Go to previous message
Guys,
This bugzilla has relatively complete patches (along the line of what
Martin is suggesting) for supporting this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245014
Martin Taal wrote:
> Hi Svetoslav,
> interfaces already extend EObject and Serializable does not add
> gr. Martin
> Svetoslav wrote:
>> Hi.
Previous Topic:[Transaction] Editor to use single write transaction to modify EMF model until disposed
Next Topic:How to define a Derived/Transient/Votaile Attribute in an EcoreModel (2.6M4)
Current Time: Sun Jul 20 03:40:55 EDT 2025
Powered by FUDForum. Page generated in 0.03951 seconds
