Home » Modeling » EMF » Problem in opening an editor in a multipage editor from a table
Problem in opening an editor in a multipage editor from a table [message #508524] Tue, 19 January 2010 05:16 Go to next message
I have a table which contains the EMF items and i try to open an editor in a multipage editor from the table.
this was working properly when i was in RCP plugin but the problem is coming after switching completely to EMF.
Below is the description of the problem
On clicking an element in Table Viewer , we have mapped an action delegate to it,
This action delegate calls the
IWorkbenchPage.openEditor(viewerInput, AgEditor.ID, activate);
wherein viewerInput is the IEditorInput and is set accordingly
AGEditor is the editor class which extends MultiPageEditorPart and implements IEditingDomainProvider, ISelectionProvider, IMenuListener, IViewerProvider, IGotoMarker
In the create pages method overwritten for the editor the Viewerpane is accessed by
ViewerPane viewerPane = new ViewerPane(getSite().getPage(), AgEditor.this)
However the viewerpane is got as null
Below is the code which i am using
public void createPages() {
// Creates the model from the editor input
createModel(); //This method is below
// Only creates the other pages if there is something that can be edited
if (!getEditingDomain().getResourceSet().getResources().isEmpty ())
// Create a page for the baseText view (like SpeechMarker).
if(getSite()!=null)
public Viewer createViewer(Composite parent)
return new BaseTextViewer(parent); // BaseTextViewer is one of the editor in MultiPageEditorPart
public void requestActivation() {
super.requestActivation();
((BaseTextViewer) getViewer()).setFocus();
setCurrentViewerPane(this);
* (non-Javadoc)
* @see org.eclipse.emf.common.ui.ViewerPane#setFocus()
public void setFocus()
//Viewer Pane got here is null ... The AgEditor values is present
public void createModel() {
URI resourceURI = EditUIUtil.getURI(getEditorInput());
Exception exception = null;
Resource resource = null;
try {
// Load the resource through the editing domain.
resource = editingDomain.getResourceSet().getResource(resourceURI, true);
catch (Exception e) {
exception = e;
resource = editingDomain.getResourceSet().getResource(resourceURI, false);
Diagnostic diagnostic = analyzeResourceProblems(resource, exception);
if (diagnostic.getSeverity() != Diagnostic.OK) {
resourceToDiagnosticMap.put(resource, analyzeResourceProblems(resource, exception));
editingDomain.getResourceSet().eAdapters().add(problemIndica tionAdapter);
If anyone can figure out the problem plaese provide a solution to this. I am using latest EMF v3.5. Any help provided will be deeply appreciated.
Thanks in advance
Rahul
Re: Problem in opening an editor in a multipage editor from a table [message #508606 is a reply to message #508524] Tue, 19 January 2010 10:38 Go to previous message
Rahul,
Comments below.
> delegate to it,
> AgEditor.this)
> can be edited
> if
> SpeechMarker).
> if(getSite()!=null)
> @Override
> @Override
> ((BaseTextViewer)
> * (non-Javadoc)
> * @see
> @Override
> ((BaseTextViewer)
> try {
> resource =
> exception = e;
> resource =
> exception);
> tionAdapter);
> appreciated.
Best to use a debugger. I really can't see a problem just looking at
large code snippets.
> Thanks in advance
> Rahul
Previous Topic:Problems regarding the mapping of key bindings with the EMF Model
Next Topic:Utility to obtain model root
Current Time: Sat Jul 19 09:23:58 EDT 2025
Powered by FUDForum. Page generated in 0.24328 seconds
