Home » Eclipse Projects » Rich Client Platform (RCP) » No application id has been found(Get this error when I add DLTK packages as dependencies)
No application id has been found [message #507019] Mon, 11 January 2010 12:00 Go to next message
I have an RCP application that runs perfectly but crashes when I add the following dependencies to it in the manifest file:
 org.eclipse.dltk.core;bundle-version="1.0.0",
 org.eclipse.dltk.javascript.core;bundle-version="1.0.0"
If I add that I get to see the splash screen of the application and then I get a launch error with this exception in the log:
java.lang.RuntimeException: No application id has been found.
	at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:236)
	at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Any help is appreciated...
Milton.
Re: No application id has been found [message #508195 is a reply to message #507019] Sun, 17 January 2010 09:29 Go to previous message
Hi Milton,
You did not include either one of these two plugins or one of their
dependencies.
Wim
> Hello,
> at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
> at
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
> at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> Milton.
Previous Topic:Update mechanism & feature versions
Next Topic:close perspective on switch
Current Time: Sun Jul 20 09:06:45 EDT 2025
Powered by FUDForum. Page generated in 0.02938 seconds
