Xsd derivated schema customization - how to avoiding unnecesary/useless list wrappers derivated from [message #508006] |
Fri, 15 January 2010 09:42  |
Originally posted by: murbieta.gpi.com.ar
Hi i'm generating an ecore model from a xsd. The schema defines
sequences of elements within complextypes that later are translated as
eclasses working as list "wrappers".
When i try to use this model with GMF, list wrapper are not well
received (gmf can't handle it).
It seems that there is a patch but i'd like to make it work with an
standard solution. Patch is available at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201662
So i'd need to derivate an ecore model avoiding generating list
"wrappers" when a complexType followed by a sequence is found. Or in the
other way around,i would need to customize emf
serialization/deserialization for working with wrapped list.
Next, i'll present the case:
My xsd specifies the following schema :
<xs:element name="step">
<xs:complexType>
<xs:sequence>
<xs:element ref="external-permissions" minOccurs="0" />
<xs:element ref="actions" minOccurs="0" />
</xs:sequence>
<xs:attribute name="name" type="xs:string" use="required" />
<xs:attribute name="id" type="xs:string" use="required" />
</xs:complexType>
</xs:element>
<xs:element name="steps">
<xs:complexType>
<xs:sequence>
<xs:element ref="step" maxOccurs="unbounded" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="workflow">
<xs:complexType>
<xs:sequence>
<xs:element ref="steps" />
</xs:sequence>
</xs:complexType>
</xs:element>
This schema allows specifying an xml like
<workflow>
<steps>
<step id=.../>
</steps>
</workflow>
When i derivate this schema to EMF, three Eclasses are created
WorkflowType, StepsType and StepType. The first have a reference to a
StepsType instance and this last has a list to StepType instances.Here,
the StepsType works as a decorator for the stepType list.
Here i'd need to avoid generating the StepsType Eclass.
regards
Re: Xsd derivated schema customization - how to avoiding unnecesary/useless list wrappers derivated [message #508066 is a reply to message #508006] |
Fri, 15 January 2010 13:16  |
Matias,
Comments below.
Yes, I mentioned that in your mailing list posting.
The customization of the serialization/deserialization is what those
patches are about.
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <workflow>
> <steps>
> <step id=.../>
> </steps>
> </workflow>
Unfortunately I've only gotten as far as the patches in that bugzilla
and my time is limited.
> regards
FUDForum. Page generated in 0.03267 seconds
