Home » Eclipse Projects » Equinox » create p2 repository based on features of another p2 repository
create p2 repository based on features of another p2 repository [message #505013] Thu, 24 December 2009 06:56 Go to next message
We build lots of features and bundles. We create p2 repositories for a feature or set of features. These repositories will be merged to one p2 repository. This is done as follow:
	FeaturesAndBundlesPublisherApplication application = new FeaturesAndBundlesPublisherApplication();
	application.setArtifactLocation(toRepository);
	application.setMetadataLocation(toRepository);
	String[] args = new String[] { "-publishArtifacts",
				"-publishArtifactRepository",
				"-overwriteArtifacts", "-append",
				"-source", fromRepository};
	application.run(args);
This will merge the full repository into an existing repository.
Now we want to export from the full repository a subset to a new repository based on features. So it also copies all required bundles to the new repository.
There is a possibility by using the FeaturesAndBundlesPublisherApplication by using in stead of the "-source" argument the "-bundles" and "-features" argument.
In this case we had to find out which bundles belong to the features to export.
Any suggestion how to do this is welcome.
Re: create p2 repository based on features of another p2 repository [message #505997 is a reply to message #505013] Tue, 05 January 2010 12:47 Go to previous messageGo to next message
You would use the mirror applications to slice out IUs and artifacts
from your main repo to a smaller repo. See
http://help.eclipse.org/galileo/index.jsp?nav=/2_0_20_2
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
icon14.gif  Re: create p2 repository based on features of another p2 repository [message #508023 is a reply to message #505997] Fri, 15 January 2010 10:27 Go to previous message
Thanks Paul. Your linked triggered me to rethink our approach. Rolling Eyes
We will probably use composite repositories.
Having a repository for every functional unit (include one ore more features with its plugins). The composite repository points to all available repositories. When we want to create a delivery (subset) we copy all the required repositories and generate a composite repository on top which point to all the children. The whole structure we can put in a zip-file and make that available.
Arjan.
Previous Topic:EJB call on WAS with an RAP application
Next Topic:package versioning troubles
Current Time: Sun Jul 20 03:35:46 EDT 2025
Powered by FUDForum. Page generated in 0.08980 seconds
