Home » Eclipse Projects » Remote Application Platform (RAP) » [ANN] Equinox 3.6M4 needed for CVS HEAD
Re: [ANN] Equinox 3.6M4 needed for CVS HEAD [message #507975 is a reply to message #507496] |
Fri, 15 January 2010 06:47   |
the new mechanism works perfectly. I guess the next milestone release of RAP will be bundled with the necessary equinox bundles?
as already mentioned, when working with CVS RAP, it is necessary to replace the equinox bundles (or at least the equinox.registry)
in the target platform with the 3.6M4 bundles available here: http://download.eclipse.org/equinox/drops/S-3.6M4-2009121013 01/index.php
i have one question. when running the application from eclipse, i add the -Declipse.registry.MultiLanguage=true to the VM arguments
in the running configuration. but where would i put this system property when i deploy the application as a WAR file? for now, i put
"eclipse.registry.MultiLanguage=true" in the launch.ini file and it works. is this the appropriate way for setting system properties
for the osgi environment in a servlet container?!
greetings,
-ben
Am 13.01.2010 17:36, schrieb Benjamin Muskalla:
> Hi folks,
> in order to support a native multi-language extension registry, we've
> introduced a LocaleProvider for Equinox. This requires at least Equinox
> M4 in your target platform in case you're working against CVS HEAD of RAP.
> See bug 295630 for more information.
> Regards,
> Benny
Re: [ANN] Equinox 3.6M4 needed for CVS HEAD [message #507979 is a reply to message #507975] |
Fri, 15 January 2010 07:04   |
Hi Ben,
besides the system property, equinox also introduced a new command line
option to enable the multi locale feature.
In the web.xml you can do it this way:
<!-- Enable multi-language support for the extension registry -->
<init-param>
<param-name>commandline</param-name>
<param-value>-registryMultiLanguage</param-value>
</init-param>
Benny
Benjamin Wolff wrote:
> greetings,
> -ben
>> Hi folks,
>> RAP.
>> Regards,
>> Benny
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: [ANN] Equinox 3.6M4 needed for CVS HEAD [message #507991 is a reply to message #507979] |
Fri, 15 January 2010 08:20  |
Hi Ben,
yes, that also works fine. where would i get such informations? does equinox has a new & noteworthy or something?
i couldn't find anything on the eclipse page (www.eclipse.org/equinox). for being the foundation of eclipse i think
the information on the page are very rare :P.
greetings,
-ben
Am 15.01.2010 13:04, schrieb Benjamin Muskalla:
> Hi Ben,
> <init-param>
> </init-param>
> Regards,
> Benny
>> Hi,
>> greetings,
>> -ben
>>> Hi folks,
>>> RAP.
>>> Regards,
>>> Benny
Re: [ANN] Equinox 3.6M4 needed for CVS HEAD [message #508001 is a reply to message #507991] |
Fri, 15 January 2010 04:28  |
it not documented (yet). They added the information to the Platform Help
but this is only available in newer Eclipse builds. We had the same
problem as you and looked it up in the implementation ;)
Benny
> Hi Ben,
> greetings,
> -ben
>> Hi Ben,
>> <init-param>
>> </init-param>
>> Regards,
>> Benny
>>> Hi,
>>> greetings,
>>> -ben
>>>> Hi folks,
>>>> RAP.
>>>> Regards,
>>>> Benny
Current Time: Sat Jul 19 11:43:43 EDT 2025
Powered by FUDForum. Page generated in 0.04687 seconds
