Home » Eclipse Projects » SWTBot » Dirty editor causes failing SWTBot test to block on 'Save changes?' dialog
Dirty editor causes failing SWTBot test to block on 'Save changes?' dialog [message #507873] Thu, 14 January 2010 13:22 Go to next message
Hi there,
I've got a test that exercises a JDT source editor. If the test fails
at a point when an editor is "dirty" (has unsaved changes), then the
test hangs indefinitely at the standard 'dirty dialog':
MyTest.java has been modified. Save changes?
No Cancel Yes
Ok, it may not be indefinite, but much longer than the nominal timeout
and longer than my patience allows. :-)
This is obviously undesirable, since it the failing test would prevent
the rest of the test suite from proceeding.
Has anyone seen this? Is there anything I can do to prevent or work
around this?
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Re: Dirty editor causes failing SWTBot test to block on 'Save changes?' dialog [message #507889 is a reply to message #507873] Thu, 14 January 2010 15:56 Go to previous messageGo to next message
The normal way to do this is to add a cleanup method in *all* test
classes that cleanup :)
@AfterClass public static cleanup(){
resetWorkbench();
For an implementation of resetWorkbench() see [1]
-- Ketan
[1] -
http://github.com/ketan/swtbot/blob/b1359050430337018242a3ab 77cd3461b2210e5f/org.eclipse.swtbot.eclipse.dsl/src/org/ecli pse/swtbot/eclipse/dsl/DefaultWorkbench.java#L89
On 1/14/10 3:08 PM, Robert M. Fuhrer wrote:
> Hi there,
> No Cancel Yes
> around this?
Re: Dirty editor causes failing SWTBot test to block on 'Save changes?' dialog [message #507897 is a reply to message #507889] Thu, 14 January 2010 16:16 Go to previous messageGo to next message
Many thanks!
> resetWorkbench();
> -- Ketan
> [1] -
>> Hi there,
>> No Cancel Yes
>> around this?
-- Bob
Robert M. Fuhrer
Re: Dirty editor causes failing SWTBot test to block on 'Save changes?'dialog [message #507977 is a reply to message #507897] Fri, 15 January 2010 06:45 Go to previous message
Hello Robert,
Sometimes saving the edited file is not desired. For this reason we use the
following code in our set up method:
SaveableHelper.testSetAutomatedResponse(1);
This will cause the editor to close without asking for saving the file and
without actually saving it. Keep in mind that this is an internal class,
so may change in the future.
Thanks!
Petar P
> Many thanks!
>> resetWorkbench();
>> -- Ketan
>> [1] -
>> 2210e5f/org.eclipse.swtbot.eclipse.dsl/src/org/eclipse/swtbo t/eclipse
>>> Hi there,
>>> fails at a point when an editor is "dirty" (has unsaved changes),
>>> then the test hangs indefinitely at the standard 'dirty dialog':
>>> No Cancel Yes
>>> timeout and longer than my patience allows. :-)
>>> prevent the rest of the test suite from proceeding.
>>> around this?
> Robert M. Fuhrer
> (http://x10.sf.net)
Previous Topic:Drag & drop
Next Topic:Can't access Console view?
Current Time: Sat Jul 19 10:55:53 EDT 2025
Powered by FUDForum. Page generated in 0.03736 seconds
