Home » Language IDEs » Java Development Tools (JDT) » Java - COM bridge.(need some advice)
Java - COM bridge. [message #507738] Thu, 14 January 2010 09:13
Hello guys!
I'm a novice Java programmer and need some guidance.
I need to get access to application COM interface from java code. As far as I understand it is not possible to do this using standart libraries (though even Excel can access COM inteface of other programs via VBA, mmmm....). OK, what should I do? As far as I understand I need to set up a special library called Java-COM bridge to accomplish this. I have found the following: JACOB, OLEJA, j-interop.
My questions are:
1) Am I on the right way for accomplishing my task?
2) Which package to choose?
3) The libraries I mentioned are not very new. May be, something has changed now and there is a common simple way to do my task?
Thanks for your attention!
Previous Topic:jar file problem
Next Topic:Eclipse broken (again)
Current Time: Sun Jul 20 12:17:34 EDT 2025
Powered by FUDForum. Page generated in 0.03258 seconds
