WorkbenchWindowControlContribution resize problem in trim area [message #506896] |
Mon, 11 January 2010 04:44  |
Hi group,
I added my own WorkbenchWindowControlContribution to the trim area of
the status bar:
<extension point="org.eclipse.ui.menus">
<menuContribution locationURI="toolbar:org.eclipse.ui.trim.status">
<toolbar id="myToolbar">
<control id="myControl" class="MyContribution" />
</toolbar>
</menuContribution>
</extension>
"myControl" contains a Composite with Labels and Images. If the text of
a Label changes, I call pack() on the Composite and the Composite
resizes correctly. However the parent does not. If the text grows, the
composite will be truncated. I have to drag my contribution to a
different position (top, left or right) and back to make it resize
correctly.
I tried nearly anything to make it realise the resize. The following has
no effect from within the composite:
this.layout();
getParent().layout();
getParent().pack();
myContribution.update();
myContribution.getParent().markDirty();
myContribution.getParent().update(true);
So the question is: Is there any way to convince the
toolbar/ControlContribution/trimArea to recognize the change in the size
and layout itself?
Jan
Re: WorkbenchWindowControlContribution resize problem in trim area [message #507516 is a reply to message #507514] |
Wed, 13 January 2010 13:17   |
Originally posted by: jccanova.gmail.com
Assume the "receiver" means "this" (Carolyn - Answer 2 days ago - in swt
forum).
The part changed argument (first boolean) means that "no flushCache()"
method call will be called if you passed as "false"... i guess the cache in
question means that some property of the layout
is cached in some Layout classes.
I still need to know which layout has a cache and which does not. I guess
your question if good for the eclipse SWT .. i guess.
Carolyn from IBM is a subject matter expert in SWT in the swt forum.
The Javadoc stands the following. in the layout(bool,bool).
* If the receiver has a layout, asks the layout to <em>lay out</em>
* (that is, set the size and location of) the receiver's children.
* If the changed argument is <code>true</code> the layout must not rely
* on any information it has cached about its children. If it
* is <code>false</code> the layout may (potentially) optimize the
* work it is doing by assuming that none of the receiver's
* children has changed state since the last layout.
* If the all argument is <code>true</code> the layout will cascade down
* through all child widgets in the receiver's widget tree, regardless of
* whether the child has changed size. The changed argument is applied to
* all layouts. If the all argument is <code>false</code>, the layout will
* <em>not</em> cascade down through all child widgets in the receiver's
widget
* tree. However, if a child is resized as a result of a call to layout,
the
* resize event will invoke the layout of the child. Note that
* a layout due to a resize will not flush any cached information
* (same as <code>layout(false)</code>).
* </p>
* <p>
* Note: Layout is different from painting. If a child is
* moved or resized such that an area in the parent is
* exposed, then the parent will paint. If no child is
* affected, the parent will not paint.
* </p>
"Jose Carlos Canova" <jccanova@gmail.com> wrote in message
news:hil22c$qg0$1@build.eclipse.org...
> Have you tried composite.getParent().layout(true, true). ?
> this means that the parent will check if the control (parent) need a
> resize and cascade the method call to its children.
> In matter of fact... layout ()... call the method bellow passing the
> second parameter as false. while the layout (true,true) call the same
> method passing the second argument as true... also if you understand what
> this method bellow does... let me know :).
> void updateLayout (boolean resize, boolean all) {
> Composite parent = findDeferredControl ();
> if (parent != null) {
> parent.state |= LAYOUT_CHILD;
> return;
> if ((state & LAYOUT_NEEDED) != 0) {
> boolean changed = (state & LAYOUT_CHANGED) != 0;
> state &= ~(LAYOUT_NEEDED | LAYOUT_CHANGED);
> if (resize) setResizeChildren (false);
> layout.layout (this, changed);
> if (resize) setResizeChildren (true);
> if (all) {
> state &= ~LAYOUT_CHILD;
> Control [] children = _getChildren ();
> for (int i=0; i<children.length; i++) {
> children [i].updateLayout (resize, all);
> Just a question is you composite inside the toolbar or you have a button
> that when pressed shows your composite passing as argument the parent ?
> regards.
> "Jan" <jan.kuenstler@bader-jene.de> wrote in message
> news:hikuld$uig$1@build.eclipse.org...
>> myToolbar is only resizing/redraw correctly on mouse drag. There must be
>> a way to this programmatically.
>> Anyone?
Re: WorkbenchWindowControlContribution resize problem in trim area [message #1079877 is a reply to message #758287] |
Mon, 05 August 2013 03:31  |
Hi , i had this problem with it. And try to fixed it according to your solution. But the application always error below when a inner Class Observer call getParent().update(true) this line : java.lang.IllegalArgumentException: Argument not valid. So how to fix it?
protected Control createControl(Composite parent) {
if (!init) {
composite = new Composite(parent, SWT.NONE);
composite.setLayoutData(new GridData(SWT.LEFT, SWT.CENTER, true, true));
composite.setLayout(new GridLayout());
labelStatus = new Label(composite, SWT.NONE);
labelStatus.setLayoutData(new GridData(SWT.LEFT, SWT.CENTER, true, true));
CurrentLabelManager.getLabelObserver().addObserver(selectionObserver);
init = true;
if (!labelStatus.isDisposed())
labelStatus.setText(status);
return composite;
Observer selectionObserver = new Observer(){
public void update(Observable o, Object arg) {
List<MultiItem> selectionList = (List<MultiItem> )arg;
if (selectionList != null && selectionList.size()!= 1) {
labelStatus.setText(selectionList.size() + " rows selected");
} else {
PhoneLabel label = CurrentLabelManager.getCurrentLabel();
if (label != null ) {
StringBuffer sb = new StringBuffer();
sb.append("Product:" + label.getProductName());
sb.append(" ");
sb.append("Module:"+label.getModuleName());
sb.append(" ");
sb.append("Label:"+label.getName());
sb.append(" ");
sb.append("Master text:"+label.getMasterText().getColumnText(ColumnCodes.MASTER_TXT));
// if (!labelStatus.isDisposed())
// labelStatus.setText(sb.toString().trim());
status = sb.toString();
SelectedLabelInfoControl.this.updateStatus();
private void updateStatus(){
* for void happen widge is disposed error.
public boolean isDynamic(){
return true;
FUDForum. Page generated in 0.09447 seconds
