Home » Language IDEs » Java Development Tools (JDT) » Eclipse builder problem(does the internal eclipse builder fully comply to standards?)
Eclipse builder problem [message #506735] Sat, 09 January 2010 05:16 Go to next message
yesterday I ran into trouble with eclipse. While using the "internal java builder" the following code compiles an produces some output. Using "javac" via commandline the process fails with an assignment compatibility problem.
Is this a known problem? Or did I get something wrong?
enum test{A,B}
class EnumTest{
    public void enumTest(Enum<?> enumValue){
        test b = (test) enumValue;
//        test b = test.class.cast(enumValue);
        System.out.println(b);
public class TestProject {
        new EnumTest().enumTest(test.B);
Re: Eclipse builder problem [message #506756 is a reply to message #506735] Sat, 09 January 2010 10:23 Go to previous messageGo to next message
Le 2010-01-09 05:16, threadpool a écrit :
> enum test{A,B}
> class EnumTest{ public void enumTest(Enum<?> enumValue){ test b = (test)
> enumValue; // test b = test.class.cast(enumValue);
> System.out.println(b); } }
> public class TestProject { public static void main(String[] args) { new
> EnumTest().enumTest(test.B); } }
What version of Eclipse are you using?
Please open a bug report against JDT/Core and we will investigate.
Olivier
Re: Eclipse builder problem [message #506761 is a reply to message #506756] Sat, 09 January 2010 11:46 Go to previous message
I'm using eclipse 3.5 - Galileo.
Previous Topic:Ant editor warning about missing AnnotationProcessorFactory class
Next Topic:Eclipse compile problem
Current Time: Sun Jul 20 09:50:39 EDT 2025
Powered by FUDForum. Page generated in 0.03790 seconds
