Re: local Eclipse help with remote content [message #507340 is a reply to message #507128] |
Tue, 12 January 2010 19:36  |
Juergen Weber wrote on Tue, 12 January 2010 04:33 | Thanks, that's great, I got it working.
But, the toc.xml itself cannot be pulled from the web server?
Also, it would be nice if you could set a base url in the toc instead for each html source:
<toc label="My Example Book" topic="index.html" baseurl="http://myserver/help/myapp/">
Greetings,
Juergen
You can also have a remote table of contents. If you go to the help / remote content preference page you can specify an infocenter to use that will provide content for you. For example you can set http://help.eclipse.org/galileo/index.jsp as your remote infocenter and then the documents from that site will appear in your local help system.
This feature is intended to allow products to have some or all of their documentation provided from a remote server.
FUDForum. Page generated in 0.04349 seconds
