Home » Modeling » EMF » Multiple Serializations
Multiple Serializations [message #506251] |
Wed, 06 January 2010 12:10  |
Originally posted by: jseng.valen.trick.gov
I am new to EMF and am trying to find documentation on how to do something
not mentioned in the tutorials.
As background, I need to generate classes that serialize to/de-serialize
from a specific schema.
The toolkit manages serialization of all objects for me; however, it does
so by managing child objects separate from object data. This means that I
need to do the following:
a) keep the toolkit's child list in sync with the EMF child list, and
b) provide a second serialization method that serializes the object
identical to the schema, but without its children.
Where should I look in the documentation for serializing/de-serializing
with and without children? And is this compatible with generation from a
schema?
Thank you.
Re: Multiple Serializations [message #506258 is a reply to message #506251] |
Wed, 06 January 2010 12:17   |
--------------070800090202060508040700
Jonathan,
Comments below.
Like this?
Tutorial: Generating an EMF Model using XML Schema
< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html>
What toolkit are you referring to?
> and
You could specialize methods like XMLSaveImpl.shouldSaveFeature to omit
certain ones.
> schema?
There's not much detailed documentation of these low level aspects of
the framework. Best to look at the source code, which is often done
best by setting breakpoints and watching the live behavior; setting a
breakpoint in the method I mentioned above would be a good start.
> Thank you.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Jonathan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:pan.2010.01.06.17.10.14.182348@valen.trick.gov"
type="cite">
<pre wrap="">I am new to EMF and am trying to find documentation on how to do something
from a specific schema.</pre>
</blockquote>
Like this? <br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html">Tutorial:
Generating an EMF Model using XML Schema</a><br>
</blockquote>
type="cite">
<pre wrap="">
a) keep the toolkit's child list in sync with the EMF child list,</pre>
</blockquote>
What toolkit are you referring to?<br>
type="cite">
<pre wrap=""> and
</pre>
</blockquote>
certain ones.<br>
type="cite">
<pre wrap="">
schema?
</pre>
</blockquote>
breakpoint in the method I mentioned above would be a good start.<br>
type="cite">
<pre wrap="">
Thank you.
</pre>
</blockquote>
</body>
</html>
--------------070800090202060508040700--
Re: Multiple Serializations [message #506284 is a reply to message #506258] |
Wed, 06 January 2010 13:54   |
The toolkit in question is a proprietary toolkit not released publicly
that I cannot even provide documentation for.
>> certain ones.
Let me try to follow this...
When EMF generates my model and classes from my schema, it should generate
an XMLSaveImpl derived class to do the serialization. This works when I
want to serialize everything. I would then create a class derived from
this serializer and override shouldSaveFeature() to return false to block
all contained elements. I would follow the debugger to find how/when to
specify the correct serializer.
In the general case, one would check per object and feature in
shouldSaveFeature() possibly deferring to the super class. Since I do not
want any child elements, I would return false for all EStructuralFeatures.
Please let me know if I did not follow correctly.
Thank you,
Jonathan
On Wed, 06 Jan 2010 12:17:25 -0500, Ed Merks wrote:
> Jonathan,
> Comments below.
> Like this?
>> and
> certain ones.
>> schema?
>> Thank you.
Re: Multiple Serializations [message #506286 is a reply to message #506284] |
Wed, 06 January 2010 14:02   |
--------------090407030100000508050202
Jonathan,
Comments below.
>>> certain ones.
No, it's not generated. It's a reusable component of the framework that
works using EMF reflection for all models.
> This works when I
No, you'd specialize your own derived XMLResourceImpl and use that to
create a derived XMLSaveImpl and in there add your logic. A model
generated from an XML schema will already have an XyzResourceImpl as the
basis for this work.
Likely you'll compare against things like XyzPackage.Literals.ABC__DEF.
So often it's easier to use the debugger to answer questions. Set a
breakpoint, serialize your instance (i.e., save the generated editor or
run the generated XyzExample.java in the *.test project when you invoke
Generate Test Code), and see what's going on.
> Thank you,
> Jonathan
>> Jonathan,
>> Comments below.
>> Like this?
>>> and
>> certain ones.
>>> schema?
>>> Thank you.
<html>
<head>
</head>
Jonathan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:pan.2010.01.06.18.54.29.122644@valen.trick.gov"
type="cite">
<pre wrap="">The toolkit in question is a proprietary toolkit not released publicly
</pre>
<blockquote type="cite">
<pre wrap="">You could specialize methods like XMLSaveImpl.shouldSaveFeature to omit
certain ones.
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
an XMLSaveImpl derived class to do the serialization. </pre>
</blockquote>
that works using EMF reflection for all models.<br>
type="cite">
<pre wrap=""> This works when I
</pre>
</blockquote>
the basis for this work.<br>
type="cite">
<pre wrap="">
</pre>
</blockquote>
Likely you'll compare against things like XyzPackage.Literals.ABC__DEF.<br>
type="cite">
<pre wrap="">
</pre>
</blockquote>
Generate Test Code), and see what's going on.<br>
type="cite">
<pre wrap="">
Thank you,
Jonathan
</pre>
<pre wrap="">Jonathan,
Comments below.
</pre>
</pre>
</blockquote>
<pre wrap="">Like this?
<a class="moz-txt-link-rfc2396E" href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html">< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html></a>
</pre>
<pre wrap="">The toolkit manages serialization of all objects for me; however, it does
</pre>
</blockquote>
<pre wrap="">What toolkit are you referring to?
</pre>
<pre wrap=""> and
</pre>
</blockquote>
certain ones.
</pre>
<pre wrap="">Where should I look in the documentation for serializing/de-serializing
schema?
</pre>
</blockquote>
<pre wrap="">There's not much detailed documentation of these low level aspects of
</pre>
<pre wrap="">Thank you.
</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------090407030100000508050202--
Re: Multiple Serializations [message #516441 is a reply to message #516440] |
Tue, 23 February 2010 12:52   |
Jonathan,
Comments below.
> I was able to implement and use my own XMLSaveImpl with some debugger
> tracing.
> This EMF project is based on a schema file; however, the output does not
> follow the schema -- the XML tags are wrong. I am using the new / special
> resourceFactoryImpl to not save children -- verified by the debugger.
Are you using the load and save options that are in the generated
resource factory? It looks like this:
public Resource createResource(URI uri)
XMLResource result = new LibraryResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER,
Boolean.TRUE);
return result;
> Further, reading fails with a Feature not found exception. Changing the
> in the debugger to the right tag fails the same (though listing the tag
> name it was changed to).
It's hard to comment without something more specific, i.e., what's
wrong? What would be right?
> The only thing strange I noticed was that I am using
> an empty URI in the resourceSet.createResource() call
> and then using resource.save(stream, null). When saving to a file, I use
> a file name with the right extension and resource.save(null).
> Any ideas?
I don't really understand what's wrong with the XML. An example would
likely help.
> Jonathan
Re: Multiple Serializations [message #516669 is a reply to message #516441] |
Wed, 24 February 2010 12:33   |
Ed,
Right vs. wrong: When I first tried EMF, I copied example code which used
XmlResourceFactoryImpl. This produced different output (XML tags like
prl:ObjectiveInstructionType) than using the generated
PrlResourceFactoryImpl (XML tags like prl:Objective as specified in the
schema used to generate the EMF classes).
My first thought was that the following code sets a factory for the
default extension "*", which might not match the empty URI I use when
setting up to write to a string:
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(
Resource.Factory.Registry.DEFAULT_EXTENSION, resourceFactoryImpl);
Code follows.
Thank you,
Jonathan
Replacement Factory Impl to replace the XMLSaveImpl:
public class ChildlessPrlResourceFactoryImpl extends PrlResourceFactoryImpl {
* Creates an instance of the resource factory.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public ChildlessPrlResourceFactoryImpl() {
super();
* Creates an instance of the resource.
* @generated
public Resource createResource(URI uri) {
XMLResource result = new ChildlessPrlResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER, Boolean.TRUE);
return result;
public class ChildlessPrlResourceImpl extends PrlResourceImpl {
* @param uri the URI of the new resource.
* @generated
public ChildlessPrlResourceImpl(URI uri) {
super(uri);
protected XMLSave createXMLSave()
return new ChildlessPRLSaveImpl(createXMLHelper());
public class ChildlessPRLSaveImpl extends XMLSaveImpl {
public ChildlessPRLSaveImpl(XMLHelper helper) {
super(helper);
protected boolean shouldSaveFeature(EObject o, EStructuralFeature f)
if(!super.shouldSaveFeature(o, f)) {
return false;
return f instanceof EAttribute;
The following is a chop-up of the tutorial to do full tree file
serialization / deserialization and childless save to / load from a
string:
public class EMFResourceUtil {
private static Logger logger = LoggerFactory.getLogger(EMFResourceUtil.class);
private final ResourceSet resourceSet;
private Resource resource = null;
public EMFResourceUtil(ResourceFactoryImpl resourceFactoryImpl) {
// Create a resource set.
resourceSet = new ResourceSetImpl();
// Register the default resource factory -- only needed for stand-alone!
private URI makeURI(String filename) {
// Get the URI of the model file.
return URI.createFileURI(new File(filename).getAbsolutePath());
public EList<EObject> read(String filename) {
URI fileURI = makeURI(filename);
resource = resourceSet.getResource(fileURI, true);
if(null == resource) {
return null;
return resource.getContents();
public EList<EObject> loadWithoutChildren(String value) {
resource = resourceSet.createResource(URI.createURI(""));
return null;
// Save the contents of the resource to the file system.
try
ByteArrayInputStream stream = new ByteArrayInputStream(value.getBytes());
resource.load(stream, null);
// TODO: improve this hack
catch (IOException e) {
logger.error(e.getMessage());
e.printStackTrace();
return null;
public void write(EObject data, String filename) {
// Create a resource for this file.
resource = resourceSet.createResource(fileURI);
// Add the book and writer objects to the contents.
resource.getContents().add(data);
try
resource.save(null);
catch (IOException e) {}
public String saveWithoutChildren(EObject data) {
try
ByteArrayOutputStream stream = new ByteArrayOutputStream();
resource.save(stream, null);
return stream.toString();
return "";
public void close() {
if(null != resource) {
resource.unload();
Save to file usage:
EMFResourceUtil util = new EMFResourceUtil(new PrlResourceFactoryImpl());
util.write(eObject, pathname);
util.close();
Load from file usage:
EList<EObject> contents = util.read(pathname);
EObject newEObject = contents.get(0);
util.close();
Save without children to string:
EMFResourceUtil util = new EMFResourceUtil(new ChildlessPrlResourceFactoryImpl());
String contents = util.saveWithoutChildren(eObject);
util.close();
Load from string:
EList<EObject> contents = util.loadWithoutChildren(value);
util.close();
On Tue, 23 Feb 2010 17:44:05 -0500, Ed Merks wrote:
> Jonathan,
> Comments below.
>> tracing.
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> return result;
>> Any ideas?
> likely help.
>> Jonathan
Re: Multiple Serializations [message #516711 is a reply to message #516669] |
Wed, 24 February 2010 16:09   |
Further investigation reveals that saving to file is saving with the
correct tags, but with href=... instead of actual data, where value of the
href attribute is the URI provided to the create resource.
In context, I have an application where the data is implemented in EMF and
the application serializes the objects from time to time maintaining
parent/child in a different mechanism than attribute data. This
serialization is returned as a byte array or String. When creating the
resource for this, I am specifying a URI when there really isn't one...
This is used to select the right factory implementation and, apparently,
as references when later saving to a file. And the saved string has tags
not agreeing with the schema used to generate the EMF project.
Thank you,
Jonathan
On Wed, 24 Feb 2010 11:33:18 -0600, Jonathan Seng wrote:
> Ed,
> Code follows.
> Thank you,
> Jonathan
> * @generated
> super();
> * @generated
> @Override
> return result;
> * @generated
> super(uri);
> @Override
> super(helper);
> @Override
> return false;
> string:
> return null;
> return null;
> try
> return null;
> try
> try
> return "";
> resource.unload();
> Save to file usage:
> util.close();
> util.close();
> util.close();
> Load from string:
> util.close();
Re: Multiple Serializations [message #516712 is a reply to message #516711] |
Wed, 24 February 2010 16:30   |
Jonathan,
I'm not sure if you're still asking question. I see no question marks
in this post or the previous one, nor do any of the sentence look like
questions, so I'll just comment.
That sounds like an XMI serialization, i.e., one that's using
XMIResourceImpl.
Yes, cross file references will use the URI of the resource containing
the referenced object.
The only reasons for this is using different options or a different
resource implementation.
> Thank you,
> Jonathan
>> Ed,
>> Code follows.
>> Thank you,
>> Jonathan
>> * @generated
>> super();
>> * @generated
>> @Override
>> return result;
>> * @generated
>> super(uri);
>> @Override
>> super(helper);
>> @Override
>> return false;
>> string:
>> return null;
>> return null;
>> try
>> return null;
>> try
>> try
>> return "";
>> resource.unload();
>> Save to file usage:
>> util.close();
>> util.close();
>> util.close();
>> Load from string:
>> util.close();
Re: Multiple Serializations [message #516715 is a reply to message #516712] |
Wed, 24 February 2010 16:35   |
Ed,
How do I get my schema-based serialization from my derived factory instead
of the XMI serialization? I believe that all of my created classes derive
from the schema generated classes....
The cross-references I am seeing are not appropriate as they are
referencing URIs inserted to create OutputStreams -- not files. How can I
override them?
Thank you,
Jonathan
On Wed, 24 Feb 2010 16:30:31 -0500, Ed Merks wrote:
> Jonathan,
> XMIResourceImpl.
>> Thank you,
>> Jonathan
Re: Multiple Serializations [message #516726 is a reply to message #516715] |
Wed, 24 February 2010 17:14   |
--------------000406090209010700090700
Jonathan,
Be sure you're extending XMLResourceImpl, not XMIResourceImpl, and
XMLSaveImpl,not XMISaveImpl. and be sure you're using the right
options. I'm pretty sure that hrefs can come only from XMI
implementation classes.
> Ed,
> override them?
> Thank you,
> Jonathan
>> Jonathan,
>> XMIResourceImpl.
>>> Thank you,
>>> Jonathan
<html>
<head>
</head>
Jonathan,<br>
<br>
implementation classes.<br>
<br>
<br>
<blockquote cite="mid:pan.2010.02.24.21.35.28.82176@valen.trick.gov"
type="cite">
<pre wrap="">Ed,
override them?
Thank you,
Jonathan
</pre>
</pre>
<pre wrap="">Further investigation reveals that saving to file is saving with the
</pre>
</blockquote>
<pre wrap="">That sounds like an XMI serialization, i.e., one that's using
XMIResourceImpl.
</pre>
<pre wrap="">In context, I have an application where the data is implemented in EMF and
</pre>
</blockquote>
<pre wrap="">Yes, cross file references will use the URI of the resource containing
</pre>
<pre wrap=""> And the saved string has tags
</pre>
</blockquote>
<pre wrap="">The only reasons for this is using different options or a different
</pre>
<pre wrap="">Thank you,
Jonathan
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------000406090209010700090700--
Re: Multiple Serializations [message #516730 is a reply to message #516726] |
Wed, 24 February 2010 17:27   |
Ed,
The generated code extends XMLResourceImpl. My code extends the generated
code. In the event that the package my code was in (the project using the
generated project) was the problem, I moved it into the generated code's
package.
I continue to have the childless string saves using the wrong tags and the
less frequent disk saves using hrefs to the URI used for the childless
string saves.
Is there anything else I can check or do?
Thank you,
Jonathan
On Wed, 24 Feb 2010 17:14:36 -0500, Ed Merks wrote:
> Jonathan,
Re: Multiple Serializations [message #516735 is a reply to message #516730] |
Wed, 24 February 2010 17:46   |
--------------090508000809050104020704
Jonathan,
My psychic abilities only extend so far...
Presumably the original unaltered resource implementation was working
correctly, right?
> Ed,
> package.
> string saves.
> Thank you,
> Jonathan
>> Jonathan,
<html>
<head>
</head>
Jonathan,<br>
<br>
My psychic abilities only extend so far... <br>
<br>
correctly, right?<br>
<br>
<br>
<blockquote cite="mid:pan.2010.02.24.22.27.22.871097@valen.trick.gov"
type="cite">
<pre wrap="">Ed,
package.
string saves.
Thank you,
Jonathan
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------090508000809050104020704--
Re: Multiple Serializations [message #516742 is a reply to message #516735] |
Wed, 24 February 2010 18:06   |
Ed,
Disabling the code that does the stream saves/loads, the files save
correctly the first time. The second save gets hrefs for items saved
similarly the first time such as: <prl:Objective href="#11"/> Note that
the href lacks the file part of the URI reference, yet a file URI was used
to write this to disk.
I recall that before I started with the childless string saves, if I
opened a file, then saved it as another name, I saw hrefs for the content.
So, apparently, it recognizes that a previous save occurred and writes
refs -- even if it crosses resource sets.
Thank you,
Jonathan
On Wed, 24 Feb 2010 17:46:47 -0500, Ed Merks wrote:
> Jonathan,
> correctly, right?
Re: Multiple Serializations [message #516744 is a reply to message #516742] |
Wed, 24 February 2010 18:17   |
Jonathan,
Comments below.
> Ed,
I have a hard time believing this. I've never know save to change the
state in such a way. References to other parts of the same document will
deresolve to what you are showing; that's normal.
No, I don't think so. All these problems sound vague. I'm at a loss for
what to say. Notice again your lack of questions...
> Thank you,
> Jonathan
>> Jonathan,
>> correctly, right?
Re: Multiple Serializations [message #516888 is a reply to message #516744] |
Thu, 25 February 2010 03:22   |
Ed,
Clearly, I'm doing something wrong as I am getting results you are
having a hard time believing. None the less, I am getting them and it is
a problem.
What am I doing wrong?
Thank you,
Jonathan
On Wed, 24 Feb 2010 18:17:17 -0500, Ed Merks wrote:
> Jonathan,
> Comments below.
>> Ed,
>> Thank you,
>> Jonathan
>>> Jonathan,
>>> correctly, right?
Re: Multiple Serializations [message #516895 is a reply to message #516888] |
Thu, 25 February 2010 08:27   |
--------------070701080508030600020908
Jonathan,
If you spell out a set or reproducible steps so I can see the problem
locally, then I'll be able to help better.
One possible issue with saving to a different name is that the model may
have unresolved proxies references to the original name.
EcoreUtil.resolveAll can be used to ensure that all proxies are resolved
so that no knowledge of the original resource URIs is retained within
the model itself. Within the UI, invoking Validate... will similarly
ensure that all references are visited and resolved.
> Ed,
> a problem.
> Thank you,
> Jonathan
>> Jonathan,
>> Comments below.
>>> Ed,
>>> Thank you,
>>> Jonathan
>>>> Jonathan,
>>>> correctly, right?
<html>
<head>
</head>
Jonathan,<br>
<br>
locally, then I'll be able to help better. <br>
<br>
may have unresolved proxies references to the original name.
resolved so that no knowledge of the original resource URIs is retained
within the model itself. Within the UI, invoking Validate... will
similarly ensure that all references are visited and resolved.<br>
<br>
<br>
<blockquote cite="mid:pan.2010.02.25.13.13.54.696897@valen.trick.gov"
type="cite">
<pre wrap="">Ed,
a problem.
Thank you,
Jonathan
</pre>
Comments below.
</pre>
<pre wrap="">Ed,
</pre>
</blockquote>
<pre wrap="">I have a hard time believing this. I've never know save to change the
</pre>
<pre wrap="">I recall that before I started with the childless string saves, if I
</pre>
</blockquote>
<pre wrap="">No, I don't think so. All these problems sound vague. I'm at a loss for
</pre>
Jonathan
</pre>
correctly, right?
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------070701080508030600020908--
Re: Multiple Serializations [message #516896 is a reply to message #516895] |
Thu, 25 February 2010 08:42   |
Ed,
I will try the resolveAll() next; however, I just found an issue that may
render this moot.
In order to save an EObject (to file or stream), I must put it in a
Resopurce's contents and save the resource. However, this removes the
object from its parent. (That is, in the debugger,
resource.getContents().add(eobject) leaves eobject with eobject.eContainer
== null first observed by the application losing the parent/child).
Is there a way to save just an object (without its children) without
putting it by itself in a resource?
If not, then I have to change my implementation from keeping a full EMF
tree and saving each object individually, to only assmebling a full EMF
tree for saving the whole file and validating.
Thank you,
Jonathan
On Thu, 25 Feb 2010 08:27:00 -0500, Ed Merks wrote:
> Jonathan,
Re: Multiple Serializations [message #516908 is a reply to message #516895] |
Thu, 25 February 2010 09:00   |
Ed,
When writing to a file, I do the following:
EcoreUtil.resolveAll(resource);
try
The file continues to write hrefs.
Any other thoughts to force these references not to occur? Or, any other
issues to look for as I hunt through the documentation for similar issues?
Thank you,
Jonathan
> Jonathan,
Re: Multiple Serializations [message #516925 is a reply to message #516896] |
Thu, 25 February 2010 09:13   |
--------------050404090007040602010002
Jonathan,
Comments below.
> Ed,
> render this moot.
Yes, but proxy resolving containments that's not the case.
EcoreUtil.copy could be used to save a copy instead of the original. It
copies the full tree, but you can specialize the EcoreUtil.Copier not to
do that.
No.
Copying an object without copying any contained children should be
relatively simple and cheap.
> Thank you,
> Jonathan
>> Jonathan,
<html>
<head>
</head>
Jonathan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:pan.2010.02.25.13.42.37.329488@valen.trick.gov"
type="cite">
<pre wrap="">Ed,
render this moot.
</pre>
</blockquote>
It copies the full tree, but you can specialize the EcoreUtil.Copier
not to do that.<br>
type="cite">
<pre wrap="">
</pre>
</blockquote>
No.<br>
type="cite">
<pre wrap="">
</pre>
</blockquote>
relatively simple and cheap.<br>
type="cite">
<pre wrap="">
Thank you,
Jonathan
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------050404090007040602010002--
Re: Multiple Serializations [message #516926 is a reply to message #516908] |
Thu, 25 February 2010 09:15   |
--------------090108040806060607070409
Jonathan,
Comments below.
> Ed,
> try
The original generated resource implementation for your schema derived
model didn't do that though, right?
> Thank you,
> Jonathan
>> Jonathan,
<html>
<head>
</head>
Jonathan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:pan.2010.02.25.14.00.08.546897@valen.trick.gov"
type="cite">
<pre wrap="">Ed,
try
</pre>
</blockquote>
model didn't do that though, right?<br>
type="cite">
<pre wrap="">
Thank you,
Jonathan
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------090108040806060607070409--
Re: Multiple Serializations [message #517039 is a reply to message #516925] |
Thu, 25 February 2010 15:45   |
Ed,
Copying before save (to file or stream) fixes all hrefs except those
caused by opening a file then saving it. This defers the problem, but
does not solve it.
I realized that the saving to stream of an EObject that was not the root
node was serializing with the tagname of the child feature type when I was
expecting to see the child feature name. This makes sense since the
EObject is being saved without reference to a containing feature.
However, load() from stream does not recognized the tag. What can I do to
get load() to recognize an arbitrary element from within the schema?
Thank you,
Jonathan
On Thu, 25 Feb 2010 09:13:02 -0500, Ed Merks wrote:
> Jonathan,
> Comments below.
>> Ed,
>> render this moot.
> do that.
> No.
>> Thank you,
>> Jonathan
Re: Multiple Serializations [message #517043 is a reply to message #517039] |
Thu, 25 February 2010 16:23  |
--------------090106010500020406030903
Jonathan,
This option might be useful:
* Write only the subtree starting at the specified list of EObjects,
* which must be objects contained by the resource.
String OPTION_ROOT_OBJECTS = "ROOT_OBJECTS";
If the child object is serialized using a tag that corresponds to a
global element declaration then you should be able to deserialize it as
well. If not, your serialization doesn't conform to a schema anyway, so
you might as well use an XMI serialization.
> Ed,
> does not solve it.
> Thank you,
> Jonathan
>> Jonathan,
>> Comments below.
>>> Ed,
>>> render this moot.
>> do that.
>> No.
>>> Thank you,
>>> Jonathan
<html>
<head>
</head>
Jonathan,<br>
<br>
This option might be useful:<br>
<blockquote> /**<br>
<br>
* which must be objects contained by the resource.<br>
*/<br>
String OPTION_ROOT_OBJECTS = "ROOT_OBJECTS";<br>
</blockquote>
you might as well use an XMI serialization.<br>
<br>
<br>
<blockquote cite="mid:pan.2010.02.25.20.45.02.906254@valen.trick.gov"
type="cite">
<pre wrap="">Ed,
does not solve it.
Thank you,
Jonathan
</pre>
Comments below.
</pre>
<pre wrap="">Ed,
render this moot.
</pre>
</blockquote>
<pre wrap="">Yes, but proxy resolving containments that's not the case.
do that.
</pre>
<pre wrap="">Is there a way to save just an object (without its children) without
</pre>
</blockquote>
<pre wrap="">No.
</pre>
<pre wrap="">If not, then I have to change my implementation from keeping a full EMF
</pre>
</blockquote>
<pre wrap="">Copying an object without copying any contained children should be
</pre>
Jonathan
</pre>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------090106010500020406030903--
Current Time: Sat Jul 19 13:41:06 EDT 2025
Powered by FUDForum. Page generated in 0.08276 seconds
