Home » Language IDEs » ServerTools (WTP) » WSDL - using IP addr instead of hostname(I want to have the WSDL use the host name instead of IP addr)
WSDL - using IP addr instead of hostname [message #505771] Mon, 04 January 2010 16:04 Go to next message
New to web services and axis2.
I am creating web services using Eclipse Galileo/Axis2.
I did get my services deployed and running, but was informed that the wsdl (seen from browser) has our IP address instead of our hostname. Is there an easy way to change this?? Can someone point me in the right direction.
The WSDL's line that has the problem is:
'<soap:12:address location=######/>'
where ###### is our IP address.
Thanks for the help
Larry
Re: WSDL - using IP addr instead of hostname [message #506248 is a reply to message #505771] Wed, 06 January 2010 11:51 Go to previous message
Hi Larry,
Did you author the WSDL file yourself or are you depending on Axis2 to
generate it for you? If you authored it yourself, simply change the
location in the file. If Axis2 is generating the file, I expect that it
picks up the server name from the application server or some other
location (hostname) that you'll need to change.
Lawrence
Previous Topic:Security Constraint not working with Tomcat Server in Eclipse
Next Topic:Unable to install WTP - missing requirements
Current Time: Sun Jul 20 10:00:23 EDT 2025
Powered by FUDForum. Page generated in 0.03285 seconds
