Home » Modeling » EMF » How to copy EObjects from one Resource to another
How to copy EObjects from one Resource to another [message #505711] Mon, 04 January 2010 11:01 Go to next message
Hi all,
I have a problem concering the storage (files) of eObjects.
SETTING:
I have a Model which is composed of different sub-diagrams. I'm actually
trying to implement a "new model wizard" which allows to create a model
from several predefined models by selecting and combining sub-diagrams.
Actually I
1) Scan a specified directory for exsiting model files (templates) and
load them.
(works fine)
2) The wizard displays all sub-diagrams and the user can select the
desired combination
(works fine)
3) I use ECoreUtil.copy(SUBDIAGRAM) to create copies of the subdiagrams
and insert them into a newly created model object (created using the
eFactory.INSTANCE of the model).
(Here is where the problems occur)
4) I create a resource and use default wizard code to save the model in
its own file.
PROBLEMS:
The problem I encounter is that the sub-diagrams are only stored as
proxies with the "template file" as eStorage(). Thus all modifications
to the diagrams affect the template (The models relations to the
subdiagrams are set to containment). Moreover, in some cases the
CannonicalEditPolicy fails to update the newly created file on opening
it. The app freezes and crashes with a "Java Heap Space Overflow"
Exception. (The application is set to 1gb Memory and it takes close to a
minute until the error is thrown)
I use ECoreUtil to copy the eObjects (sub-diagrams), but they still
refer to the template file and are only stored as references (href) in
the created model file.
(Modelfile entry:
<SUBDIAGRAM xmi:type="DIAGRAM_TYPE"
href="file:/PATH_TO_THE_TEMPLATEFILE#_QGcG0OMxEd6pZ6tfMeq-ww "/>
MY QUESTION:
Is there any easy way to create a real copy of an eObject (in a way that
it will be contained in the new file) or is it possible to somehow
clear the link to the template file?
I already tried to "resolveAll(eObject)" but this makes no difference :)
In my understanding this only surpresses the load on demand behavior
of distributed models.
Sorry for the long text and thank you for your answers and hints in advance!
With Regards,
Daniel
Re: How to copy EObjects from one Resource to another [message #505725 is a reply to message #505711] Mon, 04 January 2010 11:33 Go to previous messageGo to next message
Daniel,
Comments below.
Daniel Rippel wrote:
> Hi all,
> SETTING:
> actually trying to implement a "new model wizard" which allows to
> create a model from several predefined models by selecting and
> Actually I
> load them.
> (works fine)
> desired combination
> (works fine)
> subdiagrams and insert them into a newly created model object (created
> using the eFactory.INSTANCE of the model).
I suspect if you're calling copy multiple times you should really be
calling copyAll just once...
> in its own file.
> PROBLEMS:
You're saying there are unresolved proxies when you load the new result,
or when you're loading the thing to be copied?
> Thus all modifications to the diagrams affect the template (The models
> relations to the subdiagrams are set to containment). Moreover, in
> some cases the CannonicalEditPolicy fails to update the newly created
> file on opening it. The app freezes and crashes with a "Java Heap
> Space Overflow" Exception. (The application is set to 1gb Memory and
> it takes close to a minute until the error is thrown)
> (Modelfile entry:
Only containment references are copied recursively. Non-containment
references will refer to a copy only if the referenced object has also
been copied at the same time.
> MY QUESTION:
> that it will be contained in the new file) or is it possible to
> somehow clear the link to the template file?
Do you want this reference to end up null in the copy even though it's
non-null in the original? You'd have to do that manually... Or is the
problem that the template file should also be copied?
> :) In my understanding this only surpresses the load on demand
> behavior of distributed models.
Yes, it forces early resolves.
> advance!
One question I would ask is why even make copies? Why not just move the
original objects. Moving them out of their containing resource will
have no externally visible effect on that resource unless you save it in
that modified state.
> With Regards,
> Daniel
Re: How to copy EObjects from one Resource to another [message #505814 is a reply to message #505725] Tue, 05 January 2010 03:59 Go to previous messageGo to next message
Hi Ed,
thank you for your suggestions, but I still have the same problem...
I removed all calls of "copy" and instead move the constructed model
directly into the resource. Unfortunately it still remains the same problem:
The template file constains all entries (all containment)
<MODEL xmi:id="_PU9mkeMxEd6pZ6tfMeq-ww">
<SUBDIAGRAM1 xmi:type="SUBDIAGRAM_TYPE"
xmi:id="_QGcG0OMxEd6pZ6tfMeq-ww" name="Structure Diagram">
<packagedElement xmi:type="uml:Class"
xmi:id="_QksJEOMxEd6pZ6tfMeq-ww" name="Class1"/>
xmi:id="_SfUpwOMxEd6pZ6tfMeq-ww" name="Class2">
<generalization xmi:type="uml:Generalization"
xmi:id="_WvHrAOMxEd6pZ6tfMeq-ww" general="_QksJEOMxEd6pZ6tfMeq-ww"/>
</packagedElement>
</SUBDIAGRAM1>
<SUBDIAGRAM2 xmi:type="SUBDIAGRAM_TYPE2"
xmi:id="_nC8e0OMxEd6pZ6tfMeq-ww" name="Knowledge Diagram">
xmi:id="_rJp1gOMxEd6pZ6tfMeq-ww" name="Class3">
<ownedAttribute xmi:type="uml:Property"
xmi:id="_sd_yQOMxEd6pZ6tfMeq-ww" name="Property1" aggregation="composite"/>
and so on...
After constructuing the new Diagram and saving the resource I end up with:
<MODEL xmi:id="_AaUgEfnWEd6ukN-HoOMqxQ">
href="file:/PATH#_QGcG0OMxEd6pZ6tfMeq-ww"/>
href="file:/PATH#_nC8e0OMxEd6pZ6tfMeq-ww"/>
I want the same (complete) information which is stored in the template
to be in the constructed file too. (And not just href links)
For subdiagrams which are constructed programatically this all works
fine (creating the diagram via a command and the factory classes).
I use the following code to load the templates:
URI uri = URI.createFileURI(fPath);
Resource resource = resourceSet.createResource(uri);
resource.load(Collections.EMPTY_MAP);
EList<EObject> contents = resource.getContents();
Model mdl = null;
for (EObject eObject : contents) {
if (eObject instanceof Model) {
mdl = (Model) eObject;
break;
and then select present subdiagrams by using (getXXXX() != null)
querries to determine if a sub diagram is contained in this template.
After selecting the desired sub diagrams I create an empty model and use
setXXXXX(SUBDIAGRAM) to include the selected ones. This construct is
then passed to the wizards createDiagram(URI diagramURI,
IProgressMonitor progressMonitor) method which is altered to use the
construct instead of creating a new empty model.
As you can see from the XML above all information should be stored in
the file as they all are containment references.
Ed Merks schrieb:
> Daniel,
> Comments below.
>> Hi all,
>> SETTING:
>> Actually I
>> load them.
>> (works fine)
>> desired combination
>> (works fine)
>> in its own file.
>> PROBLEMS:
>> (Modelfile entry:
>> MY QUESTION:
>> advance!
>> With Regards,
>> Daniel
Re: How to copy EObjects from one Resource to another [message #505861 is a reply to message #505814] Tue, 05 January 2010 06:39 Go to previous messageGo to next message
Daniel,
Comments below.
> Hi Ed,
> problem:
So it's not a copy problem.
> </packagedElement>
> </SUBDIAGRAM1>
> and so on...
> with:
Is the containment reference a proxy resolving one? In that case cross
resource containment is supported so it will be neccessary to explicitly
remove the subdiagrams from their resource, i.e., using
resource.getContents().remove or clear.
> Model mdl = null;
> break;
> use setXXXXX(SUBDIAGRAM) to include the selected ones. This construct
> is then passed to the wizards createDiagram(URI diagramURI,
It sounds likely that the containment reference is proxy resolving and
that you'll have to explicitly remove the referenced objects from their
containing resource.
> Ed Merks schrieb:
>> Daniel,
>> Comments below.
>>> Hi all,
>>> SETTING:
>>> Actually I
>>> and load them.
>>> (works fine)
>>> desired combination
>>> (works fine)
>>> (created using the eFactory.INSTANCE of the model).
>>> in its own file.
>>> PROBLEMS:
>> result, or when you're loading the thing to be copied?
>>> models relations to the subdiagrams are set to containment).
>>> Moreover, in some cases the CannonicalEditPolicy fails to update the
>>> newly created file on opening it. The app freezes and crashes with a
>>> "Java Heap Space Overflow" Exception. (The application is set to 1gb
>>> Memory and it takes close to a minute until the error is thrown)
>>> in the created model file.
>>> (Modelfile entry:
>> also been copied at the same time.
>>> MY QUESTION:
>> it's non-null in the original? You'd have to do that manually... Or
>> is the problem that the template file should also be copied?
>>> difference :) In my understanding this only surpresses the load on
>>> demand behavior of distributed models.
>>> advance!
>> the original objects. Moving them out of their containing resource
>> will have no externally visible effect on that resource unless you
>> save it in that modified state.
>>> With Regards,
>>> Daniel
Re: How to copy EObjects from one Resource to another [message #506100 is a reply to message #505861] Tue, 05 January 2010 21:40 Go to previous message
Thank you Ed! Removing the eObjects from the source resource works
perfectly. I Added the resource.getContents().clear; resource.unload();
and everything works fine! No heap space problems and the file looks
like it should :)
Thank you very much!
Daniel
Ed Merks schrieb:
> Daniel,
> Comments below.
>> Hi Ed,
>> problem:
>> </packagedElement>
>> </SUBDIAGRAM1>
>> and so on...
>> with:
>> Model mdl = null;
>> break;
Previous Topic:Genmodel produces Object references rather than EObject - why?
Next Topic:Newlines in generated code
Current Time: Sun Jul 20 05:37:17 EDT 2025
Powered by FUDForum. Page generated in 0.25987 seconds
