[Acceleo] Naming conflicts in modules [message #505824] |
Mon, 04 January 2010 23:47  |
I would like to know if there is a way to avoid conflicts in mtl modules / queries / templates naming.
In java, naming conflicts are resolved using packages names, but I didn't found this concept in Acceleo.
If I have a project A that defines a module "common" and a project B that defines another module "common", how can I use both modules in a project C ?
I can even not rename them into "A.common" and "B.common" because the module name must be equal to the filename.
Is there a workaround for that kind of conflict ? Something planned for the future ? A naming convention to prevent conflicts ?
Sebastien
Re: [Acceleo] Naming conflicts in modules [message #506428 is a reply to message #505824] |
Thu, 07 January 2010 04:16  |
--------------010405060603040305060309
Hi Sebastien,
You cannot name the modules A.common or B.common, yet you can name them
A::common and B::common and then import them both with the same
convention. That is the only workaround when dealing with like-named
modules.
Laurent Goubet
Obeo
Sebastien Roy wrote:
> Hello,
> project C ?
> Regards
> Sebastien
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010405060603040305060309--
FUDForum. Page generated in 0.05006 seconds
