Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Cannot find referenced template while can navigate to whith "F3" key
[Acceleo] Cannot find referenced template while can navigate to whith "F3" key [message #505193] Mon, 28 December 2009 08:59 Go to next message
I have created a Eclipse project (available at
http://code.assembla.com/mda/git/nodes?rev=master ), this project
contains some Acceleo templates.
For example template generateMainPom.mtl in m2t/acceleo/base directory
contains an error on getProjectName template call saying that there's
not exists such template but when I push "F3" key acceleo editor can
find the corresponding template. And template execution failed due to
acceleo template compilation errors.
Someone can help me to resolve my problem?
Thanks.
Re: [Acceleo] Cannot find referenced template while can navigate to whith "F3" key [message #505813 is a reply to message #505193] Mon, 04 January 2010 22:56 Go to previous message
--------------080809090603080607010103
Hi Esteban,
We've never faced this bug ourselves, and the only reason I'd see would
be a resolution failure from within the compiler (F3 uses a simpler
compilation process).
I'll try and investigate starting from your templates.
Which versions of Eclipse, OCL and Acceleo are you using?
Laurent Goubet
Obeo
Esteban DUGUEPEROUX wrote:
> Thanks.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------080809090603080607010103--
Previous Topic:[XPAND] how to derive the interface implement in xpand
Next Topic:[Acceleo] Naming conflicts in modules
Current Time: Sun Jul 20 10:54:50 EDT 2025
Powered by FUDForum. Page generated in 0.03267 seconds
