Home » Language IDEs » Objectteams » ArrayIndexOutOfBoundsException with multithreaded use of a callin
ArrayIndexOutOfBoundsException with multithreaded use of a callin [message #505683] Mon, 04 January 2010 09:02 Go to next message
Several threads accessing the the same callin cause numerous ArrayIndexOutOfBoundsException. Sources for this test case can be found on this link: sources
OTDT Version: 1.3.2 - developed for Eclipse version 3.5.1
[Updated on: Mon, 04 January 2010 09:04] by Moderator
Re: ArrayIndexOutOfBoundsException with multithreaded use of a callin [message #506203 is a reply to message #505683] Wed, 06 January 2010 09:22 Go to previous message
> Several threads accessing the the same callin causes
> this link: http://hutorny.in.ua/wp-content/uploads/2010/01/exer2.zip
I filed this ticket:
https://trac.objectteams.org/ot/ticket/331
In 1.4.0 your example actually worked and I had to enable
implicit team activation to see the exception.
The relevant change in 1.4.0 is documented here:
http://www.objectteams.org/def/1.3/s5.html#s5.3.d
Thus for 1.4.0 we have a workaround (don't use implicit
team activation) and we have a hint at what is causing
the problem.
best regards,
Stephan
Previous Topic:Suggestion on callin bindings
Next Topic:ArrayIndexOutOfBoundsException with multithreaded use of a callin
Current Time: Sat Jul 19 15:11:58 EDT 2025
Powered by FUDForum. Page generated in 0.04299 seconds
