Re: [Acceleo] Cannot find referenced template while can navigate to whith "F3" key [message #505813 is a reply to message #505193] |
Mon, 04 January 2010 22:56  |
--------------080809090603080607010103
Hi Esteban,
We've never faced this bug ourselves, and the only reason I'd see would
be a resolution failure from within the compiler (F3 uses a simpler
compilation process).
I'll try and investigate starting from your templates.
Which versions of Eclipse, OCL and Acceleo are you using?
Laurent Goubet
Obeo
Esteban DUGUEPEROUX wrote:
> I have created a Eclipse project (available at
> http://code.assembla.com/mda/git/nodes?rev=master ), this project
> contains some Acceleo templates.
> For example template generateMainPom.mtl in m2t/acceleo/base directory
> contains an error on getProjectName template call saying that there's
> not exists such template but when I push "F3" key acceleo editor can
> find the corresponding template. And template execution failed due to
> acceleo template compilation errors.
> Someone can help me to resolve my problem?
> Thanks.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------080809090603080607010103--
FUDForum. Page generated in 0.03732 seconds
