Home » Archived » Memory Analyzer (MAT) » Retained heap in histogram view
Retained heap in histogram view [message #505187] Mon, 28 December 2009 07:48 Go to next message
I am new to eclipse MAT and and a bit dubious regarding following points
In histogram view of a heap dump,
for certain class entries I get no. of objects 0 but still the retained heap shows >=2048 (i.e more than 0)
What exactly is retained heap and what does this indicate?
Also I really liked the OQL tool integrated with MAT. Is there any official tutorial to learn its syntax?
Re: Retained heap in histogram view [message #505250 is a reply to message #505187] Mon, 28 December 2009 17:55 Go to previous message
The class histogram also includes the class instance. So if there is a class with several static fields, and there are 0 instances of the class, you will still see retained heap > 0 and 0 instances.
About the OQL: if you press F1 when you open the OQL view, you should get some help and the syntax.
I hope this helps.
Previous Topic:References hold by Finalizer
Next Topic:How to setup MAT in Eclipse SDK
Current Time: Sat Jul 19 22:45:28 EDT 2025
Powered by FUDForum. Page generated in 0.03137 seconds
