Home » Archived » M2M (model-to-model transformation) » [QVT] Transformation is using UML 3.0.0 versus 2.1.0(QVT transformation using UML 3.0.0 versus 2.1.0 despite 2.1.0 in the code)
[QVT] Transformation is using UML 3.0.0 versus 2.1.0 [message #505133] Sun, 27 December 2009 09:41 Go to next message
I have a model to model transformation which I have the following line for the UML modeltype
modeltype uml uses "http://www.eclipse.org/uml2/2.1.0/UML"
but when ran - the http://www.eclipse.org/uml2/3.0.0/UML is used
the resulting xmi
<uml:Package xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xmi:id="_95WRUfL0Ed6HaaidunZbwQ" name="PORX_RM010001UK01">
At one point i did have the 3.0.0 in the transformation but required 2.1.0
In the ide - the mouse hover reads 3.0.0 over the 2.1.0 code
Is there some setting i need to change in order for 2.1.0 to be used or cache to remove?
I included below my configuration details
Thanks in advance
Sean Muir
Eclipse Project SDK
Version: 3.5.0.v20090423-7Q7bA7DPQ1SM6OYQ7wKYJhI-z-xZJCmLTBRhtZ0o61b1 z
Build id: I20090611-1540
(c) Copyright Eclipse contributors and others 2000, 2009. All rights reserved.
Visit http://www.eclipse.org/eclipse
Operational QVT Common
Version: 2.0.1.v20090722-1630-79-0AkF77g7UDT3BcL7
Build id: 200906161204
(c) Copyright Borland Software Corporation. 2007, 2008. All rights reserved.
QVT Operational Mapping Language (OML) is used for model-to-model transformation.
Visit http://www.eclipse.org/m2m
Unified Modeling Language 2.x
Version: 3.0.1.v200908281330
Build id: 200906151558
(c) Copyright Eclipse contributors and others 2003, 2008. All rights reserved.
Visit http://www.eclipse.org/uml2
Re: [QVT] Transformation is using UML 3.0.0 versus 2.1.0 [message #507057 is a reply to message #505133] Mon, 11 January 2010 15:54 Go to previous message
Hi Sean ,
Described behavior is UML-intrinsic.
UML resource is always saved with highest available version (which is
3.0.0 for UML in Eclipse 3.5). Exactly that UML metamodel is also
registered for "http://www.eclipse.org/uml2/2.0.0/UML" and
"http://www.eclipse.org/uml2/2.1.0/UML" URIs.
For any older UML-instance models implicit upward conversion is performed.
Sergey.
> the resulting xmi
> cache to remove?
> Thanks in advance
> Sean Muir
> Eclipse Project SDK
> reserved.
> reserved.
> transformation.
> reserved.
Previous Topic:Modifying GLOBALVAR in extend script
Next Topic:[QVTO] Evaluator: QvtRuntimeException by Transformation
Current Time: Sat Jul 19 14:05:21 EDT 2025
Powered by FUDForum. Page generated in 0.03390 seconds
