Home » Eclipse Projects » Rich Client Platform (RCP) » how to enable a menuitem by default
how to enable a menuitem by default [message #505075] Sat, 26 December 2009 07:52 Go to next message
I´m starting on Eclipse RCP and I try to create a simple menuitem to close the window:
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="menu:org.eclipse.ui.main.menu">
<menu
id="fileMenu"
label="File">
<command
commandId="firstapp.Exit"
label="Exit"
style="push"
tooltip="Exit the app">
</command>
</menu>
</menuContribution>
</extension>
The menuitem Exit appears in the "File" menu but it´s disabled. Anything missing?
Re: how to enable a menuitem by default [message #505095 is a reply to message #505075] Sat, 26 December 2009 13:59 Go to previous messageGo to next message
how to add an Exit command (and lots of other stuff) is described here:
http://www.vogella.de/articles/EclipseCommands/article.html
In your case you most likely missing the handler.
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
On 26.12.2009 04:52, raff wrote:
> Hi, I´m starting on Eclipse RCP and I try to create a simple menuitem to
> close the window:
> <extension
> <menuContribution
> <menu
> id="fileMenu"
> label="File">
> <command
> label="Exit"
> style="push"
> </command>
> </menu>
> </menuContribution>
> </extension>
> missing?
Re: how to enable a menuitem by default [message #505285 is a reply to message #505095] Tue, 29 December 2009 00:17 Go to previous messageGo to next message
in fact I was following one of your tutorials Smile. Nice work!
I found the problem, the code automatically generated by Eclipse for the handler returns false in isEnabled() and isHandled() functions.
Re: how to enable a menuitem by default [message #505474 is a reply to message #505285] Wed, 30 December 2009 19:38 Go to previous messageGo to next message
good to hear that you solved the problem. In case my tutorial was
incorrect, please report it: http://groups.google.com/group/vogella
Best regards, Lars
On 28.12.2009 21:17, R.Afonso wrote:
> in fact I was following one of your tutorials :). Nice work!
> Thanks
Re: how to enable a menuitem by default [message #505939 is a reply to message #505285] Tue, 05 January 2010 10:28 Go to previous message
R.Afonso wrote:
Please make sure you subclass AbstractHandler (instead of implementing
IHandler directly)
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:How to close a view?
Next Topic:Website for book Eclipse Rich Client Platform: Designing, Coding, and Packaging Java Applications se
Current Time: Sun Jul 20 17:09:50 EDT 2025
Powered by FUDForum. Page generated in 0.24655 seconds
