Home » Eclipse Projects » Standard Widget Toolkit (SWT) » More strange Cocoa behavior
More strange Cocoa behavior [message #504270] Thu, 17 December 2009 20:16 Go to next message
Have two "bugs" that I have been struggling with, but discovered to my
surprise that these bugs do not occur under Carbon, nor in Windows.
The first is that the hover text behavior in a properties viewer only gives
a single line; in Carbon, the hover text shows the entire contents of the
property. For example, if the property has a multi-line text value and I am
running on Carbon, and I hover over that property in the viewer, the
hovertext comes up and shows all lines. However, in Cocoa, only the first
line is shown.
The second is that I have a viewer that reads and displays an XML file with
a variety of decorators, etc. It is a rule trace from Drools. I am
inserting two facts into Drools and then the display is a trace of the rules
that fire. In Carbon, this viewer works perfectly, but in Cocoa, one of the
facts is completely blank. The code for this is complex and I am not
including it here - the main issue is that everything is fine in Carbon and
not fine in Cocoa.
Not at all sure if these are SWT issues or RCP issues.
- Mike
Re: More strange Cocoa behavior [message #504423 is a reply to message #504270] Fri, 18 December 2009 10:02 Go to previous message
Hi Mike,
If these work on the other platforms then they're probably bugs in swt's
Cocoa port, and you should log separate reports with swt at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT .
Be sure to provide reproducable steps (eg.- is there a quick scenario that
makes a property view entry take multiple lines? Where is Drools from and
what is the XML file that shows the problem? etc.)
Grant
"J Michael Dean" <mdean77@comcast.net> wrote in message
news:C75025EE.28A31%mdean77@comcast.net...
gives
am
> line is shown.
with
rules
the
and
> not fine in Cocoa.
> - Mike
Previous Topic:Possible to set SWT.SMOOTH on MasterDetailsBlock form?
Next Topic:clear tree selection
Current Time: Sat Jul 19 21:38:27 EDT 2025
Powered by FUDForum. Page generated in 0.03699 seconds
